Successfully built EPICS 7 with RTEMS 5 for mvme6100
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Mar 18 18:56:44 UTC 2020
Thank you so much for the feedback. I will research more on the targets
that can run with the simulator and would like to tell you that looking at
https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0, I feel that @Heinz
Junkes <junkes at fhi-berlin.mpg.de> is already working on libbsd for
RTEMS-MVME2500 and I would like to hear more from him to get some clarity
on what can be done. Being a beginner, it's really a great welcome to the
world of cross-compiler development and testing. :) Thank you for always
helping me out!
On Wed, Mar 18, 2020 at 11:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 18, 2020 at 11:40 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > Hi everyone,
> > As a part of working on ticket #3835 (BSP Buildset for EPICS), this is
> to inform the community that after a lot of research, help from RTEMS and
> EPICS community and
> https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en, I was
> able to build EPICS 7 for RTEMS 5 for mvme6100 (powerpc-rtems5).
> > After this, my development environment is almost completely set up with
> RTEMS, rtems-source-builder and epics7 (taken from
> https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0 ). While going
> through the entire process, I learnt about the changes to be made in
> epics7/configure/os/CONFIG_STATUS.Common.RTEMS and also encountered few
> errors while the 'make' process, however, it got fixed by commenting line
> 325 to 329 in
> '/home/mritunjay/development/rtems/5/powerpc-rtems5/beatnik/lib/include/rtems/confdefs/libio.h':
> > //  #ifdef CONFIGURE_FILESYSTEM_ENTRY_DEVFS
> > //    CONFIGURE_FILESYSTEM_ENTRY_DEVFS,
> > //  #endif
> > I would like to know more on why this behaviour occurred. Is it a bug?
> Or something else?
> Include some of this detail in your proposal. I don't have time at the
> moment to delve into details.
> Next step would be to identify a target you can build EPICS7+RTEMS5
> with simulator support. This one is challenging since AFAIK there
> haven't been any successes in that regards. Find out what are the
> blockers and maybe you can work on those.
> > I wanted to test it but I am facing issues in connecting with tftp
> server when I run 'scp bin/RTEMS-beatnik/libComTestHarness.boot root at epics
> :/var/lib/tftp'
> > The following error was encountered:
> > /usr/bin/ssh: /lib/x86_64-linux-gnu/libcrypto.so.1.0.0: no version
> information available (required by /usr/bin/ssh)
> > ssh: Could not resolve hostname epics: Name or service not known
> > lost connection
> > I was wondering what can be the reason behind this, please help me fix
> this.
> Test it how -- do you have a powerpc MVME6100 board?
> I'm guessing whoever gave you that scp command line has a board with a
> local /etc/hosts entry for 'epics' pointing to some local IP address
> they connect to their board over.
> Welcome to the world of cross-compiler development and testing. :)
> https://docs.rtems.org/branches/master/user/hosts/index.html#development-host
> > Also, what are the next steps? I am working on the GSoC proposal
> currently and since the current ticket #3835 is a shorter project, I have
> to add certain similar sub-tasks within the GSoC timeline as suggested by
> @Gedare Bloom :
> > "* compile CFS by hand, create an RSB "recipe" to build it, then
> > integrate it with vertical buildset configuration.
> > * create vertical buildsets for PC, Raspberry Pi, and other boards.
> > ** EPICS community uses many powerpc boards so adding something there
> > would be good."
> Identify what might be potential simulator targets for you to use, and
> look at how easy they are to build with RSB. If any are missing
> support, work on adding them. If any are broken, poke into why.
> psim is a good powerpc simulator, although it may not have enough
> support for running epics--I haven't looked.
> For EPICS it is best to get something working in qemu so that you can
> run some  networking. So I'd look at some qemu simulator targets and
> check what is their status and whether you can build and run anything
> for RTEMS on them. After that, can you build/run any RTEMS networking
> applications?
> Does the EPICS7+RTEMS5 stack still using cpukit/libnetworking, or is
> it able to use libbsd? That is an interesting question to find out.
> > I would like to have suggestions on resetting the timeline as I work on
> refining the proposal for GSoC based on Dr. @Gedare Bloom's suggestions.
> For timeline the first step is to break down all the tasks to figure
> out what you need to do to accomplish each of your goals. Then you
> should try to estimate how long you (or mentors) think each task will
> take, and use that create your plan. (Estimating time is notoriously
> difficult, but do your best. If it comes in too heavy or light, that
> is fine, you should put some activities in "Future Improvements" that
> can be moved into your summer work in case you get through your
> planned work faster than you expect; if you don't complete all your
> planned work, we understand and will take everything into
> consideration during evaluation. Do NOT think of your plan as a
> contract: it is not, it is a guideline for your summer.)
> > Thanks
> > Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200319/809f2884/attachment.html>
