RFC: Exceptions to PEP-8 Adoption for RTEMS Tools
Thu Mar 19 03:01:58 UTC 2020
On 19/3/20 7:06 am, Christian Mauderer wrote:
> Hello Amar,
> On 18/03/2020 19:24, Amar Takhar wrote:
>> The only one I would like to propose is the 80 character limit.  This should be
>> moved to something more reasonable such as 120.
>> Code comments should remain below 80 however.
> I'm not a big fan of long lines (reason further below) but I won't block
> it either. But what I think is really a bad idea is to have different
> rules for different parts of the code.
And different parts of the project.
> I think we will have a really hard time to set up tools like formatters
> or pylint to check and use these rules. I think setting a line length to
> 120 should be easy to possible for nearly any tool. But I expect that
> setting it to 120 for code and 80 for comments can be _very_ difficult
> depending on the tool.
> PS: Reason for me being not a fan of long lines: While programming I
> often use a split window. In that configuration my editor can show 112
> columns in each window on my current screen. That fits well for nearly
> all code that follows the 80 character convention. But for example your
> proposed length of 120 the code will lead to either a smaller font, a
> lot of random line breaks done by the editor or to loosing one window.
> Again: It's not a strong opinion and I'll accept 120 too. But expect
> that some others have stronger opinions about 80 characters.
I run everything in text mode under tmux and in Emacs I split vertically and
variable length is painful and prefer we settle on 80.
