[PATCH v1 01/16] Py2/3 compliant tools/gdb/python
Anmol Mishra anmol.j2020 at gmail.com
Fri Mar 20 04:18:13 UTC 2020
Hello,
How does the community test the rtems-tools changes?
In the README I can see a few steps, Is that the standard method?, It is my
first patch for rtems, help is really appreciated.
Best Regards
On Fri, Mar 20, 2020 at 3:45 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Anmol,
> On Thu, Mar 19, 2020 at 1:41 PM Anmol Mishra <anmol.j2020 at gmail.com>
> wrote:
> > Hello,
> > I can understand your requests, I also thought to squash/combine all
> changes in 1 patch. I will complete the task in a day and resend the patch.
> I did not know the protocol/contributing guide. I will keep a note of this.
> Sorry for the trouble.
> One more thing, can you please identify what, if any, testing of your
> patches that you did?
> It would be good to know they have been tried out :)
> > Regards
> > On Thu, Mar 19, 2020 at 9:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Anmol,
> >> Thanks for your patches. I have a few requests.
> >> Can you please provide some details in your commit message? In
> >> particular, since few of us right now know how to make code compliant
> >> between Python 2 and 3, can you provide a brief
> >> justification/description for what the changes are and how they
> >> address this problem?
> >> In general you can send your first set of patches without a -v1. That
> >> is implied.
> >> When you send a lot of patches it is good if you also prepare a
> >> git-cover-letter (patch 00/xx) to explain the patch set.
> >> Instead of going file-by-file with patches, you might also consider
> >> organizing patches by addressing "kinds" of compliance fixes. For
> >> example, a single patch could sweep up a bunch of "from __future__
> >> import ..." across several files. Either way is really OK, patches
> >> that touch just one file are less likely to conflict, but a patch that
> >> does one thing across many files is easier to review/approve. I'll
> >> leave it up to you how you want to proceed.
> >> On Wed, Mar 18, 2020 at 6:19 AM Anmol mishra <anmol.j2020 at gmail.com>
> wrote:
> >> > From: Anmol Mishra <anmol.j2020 at gmail.com>
> >> >  tools/gdb/python/__init__.py | 5 ++++-
> >> >  1 file changed, 4 insertions(+), 1 deletion(-)
> >> > diff --git a/tools/gdb/python/__init__.py
> b/tools/gdb/python/__init__.py
> >> > index 0ea5fb2..dfbe6ba 100644
> >> > --- a/tools/gdb/python/__init__.py
> >> > +++ b/tools/gdb/python/__init__.py
> >> > @@ -27,8 +27,11 @@
> >> >  # POSSIBILITY OF SUCH DAMAGE.
> >> > +from __future__ import print_function
> >> > +from __future__ import absolute_import
> >> >  import gdb
> >> > -import rtems
> >> > +from . import rtems
> >> >  def get_architure():
> >> >      frame = gdb.selected_frame()
> >> > 2.21.0 (Apple Git-122.2)
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200320/2c56fc89/attachment.html>
