[PATCH v1 01/16] Py2/3 compliant tools/gdb/python
Gedare Bloom
gedare at rtems.org
Thu Mar 19 22:15:20 UTC 2020
Hi Anmol,
On Thu, Mar 19, 2020 at 1:41 PM Anmol Mishra <anmol.j2020 at gmail.com> wrote:
> Hello,
> I can understand your requests, I also thought to squash/combine all changes in 1 patch. I will complete the task in a day and resend the patch. I did not know the protocol/contributing guide. I will keep a note of this. Sorry for the trouble.
One more thing, can you please identify what, if any, testing of your
patches that you did?
It would be good to know they have been tried out :)
> Regards
> On Thu, Mar 19, 2020 at 9:53 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Anmol,
>> Thanks for your patches. I have a few requests.
>> Can you please provide some details in your commit message? In
>> particular, since few of us right now know how to make code compliant
>> between Python 2 and 3, can you provide a brief
>> justification/description for what the changes are and how they
>> address this problem?
>> In general you can send your first set of patches without a -v1. That
>> is implied.
>> When you send a lot of patches it is good if you also prepare a
>> git-cover-letter (patch 00/xx) to explain the patch set.
>> Instead of going file-by-file with patches, you might also consider
>> organizing patches by addressing "kinds" of compliance fixes. For
>> example, a single patch could sweep up a bunch of "from __future__
>> import ..." across several files. Either way is really OK, patches
>> that touch just one file are less likely to conflict, but a patch that
>> does one thing across many files is easier to review/approve. I'll
>> leave it up to you how you want to proceed.
>> On Wed, Mar 18, 2020 at 6:19 AM Anmol mishra <anmol.j2020 at gmail.com> wrote:
>> > From: Anmol Mishra <anmol.j2020 at gmail.com>
>> > tools/gdb/python/__init__.py | 5 ++++-
>> > 1 file changed, 4 insertions(+), 1 deletion(-)
>> > diff --git a/tools/gdb/python/__init__.py b/tools/gdb/python/__init__.py
>> > index 0ea5fb2..dfbe6ba 100644
>> > --- a/tools/gdb/python/__init__.py
>> > +++ b/tools/gdb/python/__init__.py
>> > @@ -27,8 +27,11 @@
>> > # POSSIBILITY OF SUCH DAMAGE.
>> > +from __future__ import print_function
>> > +from __future__ import absolute_import
>> > import gdb
>> > -import rtems
>> > +from . import rtems
>> > def get_architure():
>> > frame = gdb.selected_frame()
>> > 2.21.0 (Apple Git-122.2)
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
