[PATCH v6] tests for fenv.h functions
Aditya Upadhyay
aadit0402 at gmail.com
Fri Mar 20 19:54:58 UTC 2020
Hi Eshan,
You should look into the RTEMS Coding conventions and rules. I can see
that some spaces that you inserted after
rtems_test_assert() were not needed. Please remove these unnecessary
spaces. For example,
rtems_test_assert ( r == 0 ) ; ===> should be changed to
rtems_test_assert( r == 0 )
rtems_test_assert ( fegetround() == FE_DOWNWARD ) ; ===> same here.
Thanks,
Aditya Upadhyay
On Sat, Mar 21, 2020 at 12:21 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Sat, Mar 21, 2020 at 12:19 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hello Everyone,
>> I had sent this patch a few days ago to add tests of fenv.h to psxtests.
>> If you all could look into it and tell if it could be merged or requires any more changes.
> link to patch : https://lists.rtems.org/pipermail/devel/2020-March/058063.html
>> thanks,
>> Eshan Dhawan
>> On Sun, Mar 8, 2020 at 10:32 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>> I have compiled as well as executed it for RISC V architecture function Fegetround() returns error for all rounding directions other the default "FETONEAREST" I asked about it on devel to which dr Joel told that it is due to soft-float.
>>> So I have added its test case but they won't work on emulators.
>>> thanks
>>> -Eshan
>>> On Sun, Mar 8, 2020 at 7:55 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> Hi Eshan,
>>>> This is looking good. Did you compile it? Execute it? How was the output?
>>>> On Sat, Mar 7, 2020 at 6:51 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>>>> > testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
>>>> > 1 file changed, 71 insertions(+), 18 deletions(-)
>>>> > diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>>>> > index cdb0fa596e..6d71463465 100644
>>>> > --- a/testsuites/psxtests/psxfenv01/init.c
>>>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>>>> > @@ -46,11 +46,12 @@
>>>> > #include <string.h>
>>>> > #include <rtems/test.h>
>>>> > #include <tmacros.h>
>>>> > +#include <float.h>
>>>> > const char rtems_test_name[] = "PSXFENV 01";
>>>> > /* forward declarations to avoid warnings */
>>>> > -rtems_task Init(rtems_task_argument ignored);
>>>> > +rtems_task Init( rtems_task_argument ignored );
>>>> > /* Test Function Begins */
>>>> > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
>>>> > * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
>>>> > - * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
>>>> > - * 'fetestexcept()' functions are supported by the architecture.
>>>> > + * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
>>>> > + * fetestexcept() functions are supported by the architecture.
>>>> > * Hence their testcases can be wrapped under #ifdef and #endif.
>>>> > #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>>>> > puts( "fesetenv(FE_DFL_ENV)." );
>>>> > - r = fesetenv(FE_DFL_ENV);
>>>> > - if (r)
>>>> > + r = fesetenv ( FE_DFL_ENV );
>>>> > + if ( r ) {
>>>> > printf("fesetenv ==> %d\n", r);
>>>> > - rtems_test_assert( r == 0 );
>>>> > + rtems_test_assert ( r == 0 );
>>>> > - /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>>>> > - puts( "feclearexcept(FE_ALL_EXCEPT)." );
>>>> > - r = feclearexcept(FE_ALL_EXCEPT);
>>>> > - if (r)
>>>> > + /* Test feclearexcept() and fetestexcept() in one go. */
>>>> > + puts( "feclearexcept(FE_ALL_EXCEPT)" );
>>>> > + r = feclearexcept ( FE_ALL_EXCEPT );
>>>> > + if ( r ) {
>>>> > printf("feclearexcept ==> 0x%x\n", r);
>>>> > - r = fetestexcept( FE_ALL_EXCEPT );
>>>> > - if (r)
>>>> > + r = fetestexcept ( FE_ALL_EXCEPT );
>>>> > + if ( r ) {
>>>> > printf("fetestexcept ==> 0x%x\n", r);
>>>> > /* Test 'FE_DIVBYZERO' */
>>>> > puts( "Divide by zero and confirm fetestexcept()" );
>>>> > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
>>>> > b = 1.0;
>>>> > c = b/a;
>>>> > (void) c;
>>>> > - fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>>> > + /* Test fegetexceptflag() and fesetexceptflag() */
>>>> > + r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
>>>> > + if ( r ) {
>>>> > + printf("fegetexceptflag ==> 0x%x\n", r);
>>>> > + r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
>>>> > + if ( r ) {
>>>> > + printf("fesetexceptflag ==> 0x%x\n", r);
>>>> > + /* Test for fegetround() and fesetround()
>>>> > + * They have four main macros to be tested separated by ifdef
>>>> > + * Since not all architectures support them
>>>> > + * The test case gets and sets the rounding directions */
>>>> > +#ifdef FE_TONEAREST
>>>> > + rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
>>>> > +#endif
>>>> > +#ifdef FE_TOWARDZERO
>>>> > + r = fesetround ( FE_TOWARDZERO ) ;
>>>> > + if ( r ) {
>>>> > + printf("fesetround ==> 0x%x\n", r);
>>>> > + rtems_test_assert ( r == 0 ) ;
>>>> > + rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
>>>> > +#endif
>>>> > +#ifdef FE_DOWNWARD
>>>> > + r = fesetround ( FE_DOWNWARD );
>>>> > + if ( r ) {
>>>> > + rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
>>>> > +#endif
>>>> > +#ifdef FE_UPWARD
>>>> > + r = fesetround ( FE_UPWARD );
>>>> > + if ( r ) {
>>>> > + rtems_test_assert ( fegetround() == FE_UPWARD ) ;
>>>> > +#endif
>>>> > + r = fesetround ( FE_TONEAREST );
>>>> > + if ( r ) {
>>>> > +#endif
>>>> > #ifdef FE_DIVBYZERO
>>>> > - r = feraiseexcept(FE_DIVBYZERO);
>>>> > + r = feraiseexcept ( FE_DIVBYZERO ) ;
>>>> > rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>>>> > #endif
>>>> > 2.17.1
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
