[PATCH v6] tests for fenv.h functions
Eshan Dhawan eshandhawan51 at gmail.com
Fri Mar 20 18:50:49 UTC 2020
On Sat, Mar 21, 2020 at 12:19 AM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> Hello Everyone,
> I had sent this patch a few days ago to add tests of fenv.h to psxtests.
> If you all could look into it and tell if it could be merged or requires
> any more changes.
> link to patch :*
https://lists.rtems.org/pipermail/devel/2020-March/058063.html
<https://lists.rtems.org/pipermail/devel/2020-March/058063.html>*
> thanks,
> Eshan Dhawan
> On Sun, Mar 8, 2020 at 10:32 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> I have compiled as well as executed it for RISC V architecture function
>> Fegetround() returns error for all rounding directions other the default
>> "FETONEAREST" I asked about it on devel to which dr Joel told that it is
>> due to soft-float.
>> So I have added its test case but they won't work on emulators.
>> thanks
>> -Eshan
>> On Sun, Mar 8, 2020 at 7:55 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> Hi Eshan,
>>> This is looking good. Did you compile it? Execute it?  How was the
>>> output?
>>> On Sat, Mar 7, 2020 at 6:51 AM Eshan dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>> >  testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
>>> >  1 file changed, 71 insertions(+), 18 deletions(-)
>>> > diff --git a/testsuites/psxtests/psxfenv01/init.c
>>> b/testsuites/psxtests/psxfenv01/init.c
>>> > index cdb0fa596e..6d71463465 100644
>>> > --- a/testsuites/psxtests/psxfenv01/init.c
>>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>>> > @@ -46,11 +46,12 @@
>>> >  #include <string.h>
>>> >  #include <rtems/test.h>
>>> >  #include <tmacros.h>
>>> > +#include <float.h>
>>> >  const char rtems_test_name[] = "PSXFENV 01";
>>> >  /* forward declarations to avoid warnings */
>>> > -rtems_task Init(rtems_task_argument ignored);
>>> > +rtems_task Init( rtems_task_argument ignored );
>>> >  /* Test Function Begins */
>>> > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
>>> >     * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
>>> > -   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
>>> > -   * 'fetestexcept()' functions are supported by the architecture.
>>> > +   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
>>> > +   * fetestexcept() functions are supported by the architecture.
>>> >     * Hence their testcases can be wrapped under #ifdef and #endif.
>>> >    #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>>> >      puts( "fesetenv(FE_DFL_ENV)." );
>>> > -    r = fesetenv(FE_DFL_ENV);
>>> > -    if (r)
>>> > +    r = fesetenv ( FE_DFL_ENV );
>>> > +    if ( r ) {
>>> >        printf("fesetenv ==> %d\n", r);
>>> > -    rtems_test_assert( r == 0 );
>>> > +    rtems_test_assert ( r == 0 );
>>> > -    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>>> > -    puts( "feclearexcept(FE_ALL_EXCEPT)." );
>>> > -    r = feclearexcept(FE_ALL_EXCEPT);
>>> > -    if (r)
>>> > +    /* Test feclearexcept() and fetestexcept() in one go. */
>>> > +    puts( "feclearexcept(FE_ALL_EXCEPT)" );
>>> > +    r = feclearexcept ( FE_ALL_EXCEPT );
>>> > +    if ( r ) {
>>> >        printf("feclearexcept ==> 0x%x\n", r);
>>> > -    r = fetestexcept( FE_ALL_EXCEPT );
>>> > -    if (r)
>>> > +    r = fetestexcept ( FE_ALL_EXCEPT );
>>> > +    if ( r ) {
>>> >        printf("fetestexcept ==> 0x%x\n", r);
>>> >      /* Test 'FE_DIVBYZERO' */
>>> >      puts( "Divide by zero and confirm fetestexcept()" );
>>> > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
>>> >      b = 1.0;
>>> >      c = b/a;
>>> >      (void) c;
>>> > -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>> > +    /* Test fegetexceptflag() and fesetexceptflag() */
>>> > +    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
>>> > +    if ( r ) {
>>> > +      printf("fegetexceptflag ==> 0x%x\n", r);
>>> > +    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
>>> > +    if ( r ) {
>>> > +      printf("fesetexceptflag ==> 0x%x\n", r);
>>> > +    /* Test for fegetround() and fesetround()
>>> > +     * They have four main macros to be tested separated by ifdef
>>> > +     * Since not all architectures support them
>>> > +     * The test case gets and sets the rounding directions */
>>> > +#ifdef FE_TONEAREST
>>> > +    rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
>>> > +#endif
>>> > +#ifdef FE_TOWARDZERO
>>> > +  r = fesetround ( FE_TOWARDZERO ) ;
>>> > +  if ( r ) {
>>> > +      printf("fesetround ==> 0x%x\n", r);
>>> > +  rtems_test_assert ( r == 0 ) ;
>>> > +  rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
>>> > +#endif
>>> > +#ifdef FE_DOWNWARD
>>> > +  r = fesetround ( FE_DOWNWARD );
>>> > +  if ( r ) {
>>> > +  rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
>>> > +#endif
>>> > +#ifdef FE_UPWARD
>>> > +  r = fesetround ( FE_UPWARD );
>>> > +  if ( r ) {
>>> > +  rtems_test_assert ( fegetround() == FE_UPWARD ) ;
>>> > +#endif
>>> > +  r = fesetround ( FE_TONEAREST );
>>> > +  if ( r ) {
>>> > +#endif
>>> >  #ifdef FE_DIVBYZERO
>>> > -    r = feraiseexcept(FE_DIVBYZERO);
>>> > +    r = feraiseexcept ( FE_DIVBYZERO ) ;
>>> >      rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>>> >  #endif
>>> > 2.17.1
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/79a41288/attachment.html>
