riscv BSPs on Spike due to weird RSB side-effect
Sat Mar 21 01:14:56 UTC 2020
On Fri, Mar 20, 2020 at 7:56 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I think something is wrong with the build of spike that ends up with
> a hard-coded path to inside a build tree:
> Result: invalid    Time: 0:00:01.197748 mimfs_fslink.exe
> =>  run: spike --isa=RV32IAC ./riscv-rtems5/c/rv32iac/testsuites/fstests/mimfs_fslink.exe
> ] Failed to run /home/joel/rtems-cron-5/rtems-source-builder/bare/build/tmp/sb-1001/devel/spike/home/joel/rtems-cron-5/tools/5/bin/dtc: No such file or directory
> ] Child dtb process failed
> https://lists.rtems.org/pipermail/build/2020-March/011112.html
> Does spike work if there isn't this problem?
> I can poke at the host exes to see if the dtc path is hard-coded. Otherwise, this seems very strange.
I can confirm that spike built with the RSB has the hard-coded
path to dtc that is in the temporary RSB build/staging directories.
$ strings spike | grep dtc
Failed to run
> Any ideas?
> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200320/432b83ff/attachment-0001.html>
