riscv BSPs on Spike due to weird RSB side-effect
Joel Sherrill
joel at rtems.org
Sat Mar 21 00:56:15 UTC 2020
Hi
I think something is wrong with the build of spike that ends up with
a hard-coded path to inside a build tree:
Result: invalid Time: 0:00:01.197748 mimfs_fslink.exe
=> run: spike --isa=RV32IAC
./riscv-rtems5/c/rv32iac/testsuites/fstests/mimfs_fslink.exe
] Failed to run
/home/joel/rtems-cron-5/rtems-source-builder/bare/build/tmp/sb-1001/devel/spike/home/joel/rtems-cron-5/tools/5/bin/dtc:
No such file or directory
] Child dtb process failed
https://lists.rtems.org/pipermail/build/2020-March/011112.html
Does spike work if there isn't this problem?
I can poke at the host exes to see if the dtc path is hard-coded.
Otherwise, this seems very strange.
Any ideas?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200320/e8023117/attachment.html>
