Describing relationship between rtems and gcc-cross compiler
Utkarsh Rai utkarsh.rai60 at gmail.com
Sat Mar 21 18:04:09 UTC 2020
Thanks for the feedback, I will do this as soon as possible.
On Sat, Mar 21, 2020 at 9:33 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 21, 2020, 6:14 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
>> I am interested in updating the user's guide as described in
>> https://devel.rtems.org/ticket/3912. When I had built RTEMS for the
>> first time this was one of the questions I faced, so I guess adding this
>> would be useful for new users.
>> I think we could place the differences under quick-start section 2.4
>> "Install the tool suite" as this is where the user would first come across
>> the rtems cross-compiler.
> A subsection there sounds reasonable to me.
> I would like to know as to how long should the description be and what all
>> are the differences that should be mentioned?
> I think a paragraph or two with a bullet list of key points that is
> clearly not guaranteed to be complete from the lead in text.
> The ticket mentions some key points of difference and we should have given
> you some when you asked this question. Between those, we probably have a
> solid list.
> Thanks for doing this one. I like answering questions with a URL to an
> answer. :)
> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/c5283349/attachment.html>
