[PATCH 1/1] bsps: Deletes erc32-run.ini
clrrm at isep.ipp.pt
Sun Mar 22 16:32:34 UTC 2020
tester/rtems/testing/bsps/erc32-run.ini | 38 -------------------------
1 file changed, 38 deletions(-)
delete mode 100644 tester/rtems/testing/bsps/erc32-run.ini
diff --git a/tester/rtems/testing/bsps/erc32-run.ini b/tester/rtems/testing/bsps/erc32-run.ini
deleted file mode 100644
index 3dc5f60..0000000
--- a/tester/rtems/testing/bsps/erc32-run.ini
+++ /dev/null
@@ -1,38 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2015 On-Line Applications Research Corporation (OAR).
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# The erc32 BSP
-[erc32-run]
-bsp = erc32
-arch = sparc
-tester = %{_rtscripts}/run.cfg
-bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
2.17.1
