[PATCH 0/1] Removes erc32-run.ini from rtems-tools repo
clrrm at isep.ipp.pt
Sun Mar 22 16:32:33 UTC 2020
This BSP uses 'sparc-rtems5-run' which is not being generated anymore after
compiling the toolchain. Consequently, its execution fails when being used
(i.e., when using '--rtems-bsp=erc32-run'). Thus, to make things consistent
I propose to remove this file.
Cláudio Maia (1):
bsps: Deletes erc32-run.ini
tester/rtems/testing/bsps/erc32-run.ini | 38 -------------------------
1 file changed, 38 deletions(-)
delete mode 100644 tester/rtems/testing/bsps/erc32-run.ini
2.17.1
