[PATCH 0/6] Proposes fixes for RTEMS Tester documentation page
Mon Mar 23 01:22:39 UTC 2020
On 2020-03-23 03:17, clrrm at isep.ipp.pt wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
> This set of patches proposes several fixes for RTEMS Tester
> documentation. Namely:
> - Text was reviewed and improved for clarity;
> - References to 'sparc-rtems5-run' command and 'erc32-run' were removed
>    from the documentation page. Now, the example uses 'erc32-sis' instead.
> Further references to 'sparc-rtems5-run' are still in other parts of the
> documentation (Sections 10.2 and 10.3) which also need to be updated in
> the future.
> In addition to this, I will send another patch in a different email
> which removes 'erc32-run.ini' from 'rtems-tools' repo as this BSP
> configuration uses 'sparc-rtems5-run'.
Thank you for these changes. I need to build and then read the
documentation. Some parts are fine and some changes need a closer look
to see if they are ok.
