[PATCH v3 0/3] [5-freebsd-12] Fix compilation for i386
Jan Sommer
jan.sommer at dlr.de
Mon Mar 23 08:06:09 UTC 2020
This is the backport for the 5-freebsd-12 branch to make rtems-libbsd compile for i386 again:
- It also introduces path-mappings to waf_libbsd.py as introduced here:
https://lists.rtems.org/pipermail/devel/2020-February/057457.html
Changes compared to v2:
- callout.h: Change the callout_reset_on macro
- iflib.c: Do not use different callout* macro, but use the changed one
Best regards,
Jan
Jan Sommer (3):
i386: Add missing files from FreeBSD
i386: Update build system
i386: Port to RTEMS
freebsd-org | 2 +-
freebsd/sbin/sysctl/sysctl.c | 8 +
freebsd/sys/dev/pci/pci_pci.c | 2 +
freebsd/sys/i386/include/machine/cpufunc.h | 2 +
freebsd/sys/net/iflib.c | 6756 ++++++++++++++++++++
freebsd/sys/net/iflib_private.h | 76 +
freebsd/sys/net/mp_ring.c | 554 ++
freebsd/sys/net/mp_ring.h | 75 +
freebsd/sys/sys/callout.h | 6 +
freebsd/sys/x86/include/machine/intr_machdep.h | 180 +
.../sys/{i386 => x86}/include/machine/legacyvar.h | 26 +-
freebsd/sys/{i386/i386 => x86/x86}/legacy.c | 77 +-
libbsd.py | 17 +-
rtemsbsd/i386/include/machine/clock.h | 2 +
rtemsbsd/include/rtems/bsd/local/opt_acpi.h | 0
rtemsbsd/include/x86/legacyvar.h | 1 +
rtemsbsd/include/x86/specialreg.h | 1074 ++++
rtemsbsd/include/x86/x86_var.h | 156 +
waf_libbsd.py | 13 +-
19 files changed, 8987 insertions(+), 40 deletions(-)
create mode 100644 freebsd/sys/net/iflib.c
create mode 100644 freebsd/sys/net/iflib_private.h
create mode 100644 freebsd/sys/net/mp_ring.c
create mode 100644 freebsd/sys/net/mp_ring.h
create mode 100644 freebsd/sys/x86/include/machine/intr_machdep.h
rename freebsd/sys/{i386 => x86}/include/machine/legacyvar.h (76%)
rename freebsd/sys/{i386/i386 => x86/x86}/legacy.c (89%)
create mode 100644 rtemsbsd/i386/include/machine/clock.h
create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_acpi.h
create mode 100644 rtemsbsd/include/x86/legacyvar.h
create mode 100644 rtemsbsd/include/x86/specialreg.h
create mode 100644 rtemsbsd/include/x86/x86_var.h
2.12.3
