[rtems-littlevgl PATCH] Add README
Gedare Bloom
gedare at rtems.org
Mon Mar 23 20:25:41 UTC 2020
Please add the maintainer info for the package, and/or devel at rtems.org
for questions (just in case someone picks this up somehow without
RTEMS!)
On Mon, Mar 23, 2020 at 12:44 PM Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> README.md | 34 ++++++++++++++++++++++++++++++++++
> 1 file changed, 34 insertions(+)
> create mode 100644 README.md
> diff --git a/README.md b/README.md
> new file mode 100644
> index 0000000..161e4d9
> --- /dev/null
> +++ b/README.md
> @@ -0,0 +1,34 @@
> +RTEMS LittlevGL
> +Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library using
> +waf with the required settings for running it with rtems. The lvgl drivers are
> +adapted to the BSD framebuffer and hence requires the latest rtems-libbsd build.
> +About LittlevGL
> +LittlevGL is a lightweight graphics library for embedded GUI applications. It
> +can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files that are
> +in the top of the rtems-littlevgl directory.
> +The documentation is available at:
> +https://docs.littlevgl.com/en/html/index.html
> +Building and installing rtems-littlevgl
> +git clone git://git.rtems.org/packages/rtems-littlevgl.git
> +git submodule update
> +./waf configure --prefix=/path/to/rtems/5
> +./waf build install
> +Writing embedded GUI app using rtems-littlevgl
> +The rtems-examples repository has a sample lvgl hello world application that can
> +be followed for reference on how to write and build an application with lvgl.
> +The sample app can be found here:
> +https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
> 2.21.1
> devel mailing list
> devel at rtems.org
