[rtems-littlevgl PATCH] Add README
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Mar 24 12:22:11 UTC 2020
On Tue, Mar 24, 2020, 1:55 AM Gedare Bloom <gedare at rtems.org> wrote:
> Please add the maintainer info for the package, and/or devel at rtems.org
> for questions (just in case someone picks this up somehow without
> RTEMS!)
Thanks for the review.
I'll add that in v2 once I get the @rtems address ;)
Will it be possible to also host it on GitHub?
> On Mon, Mar 23, 2020 at 12:44 PM Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > README.md | 34 ++++++++++++++++++++++++++++++++++
> > 1 file changed, 34 insertions(+)
> > create mode 100644 README.md
> > diff --git a/README.md b/README.md
> > new file mode 100644
> > index 0000000..161e4d9
> > --- /dev/null
> > +++ b/README.md
> > @@ -0,0 +1,34 @@
> > +RTEMS LittlevGL
> > +Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library
> using
> > +waf with the required settings for running it with rtems. The lvgl
> drivers are
> > +adapted to the BSD framebuffer and hence requires the latest
> rtems-libbsd build.
> > +About LittlevGL
> > +LittlevGL is a lightweight graphics library for embedded GUI
> applications. It
> > +can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files
> that are
> > +in the top of the rtems-littlevgl directory.
> > +The documentation is available at:
> > +https://docs.littlevgl.com/en/html/index.html
> > +Building and installing rtems-littlevgl
> > +git clone git://git.rtems.org/packages/rtems-littlevgl.git
> > +git submodule update
> > +./waf configure --prefix=/path/to/rtems/5
> > +./waf build install
> > +Writing embedded GUI app using rtems-littlevgl
> > +The rtems-examples repository has a sample lvgl hello world application
> that can
> > +be followed for reference on how to write and build an application with
> lvgl.
> > +The sample app can be found here:
> > +https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
> > 2.21.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200324/25f81904/attachment.html>
