[PATCH] c-user: Use new template for feature config opts
Tue Mar 24 07:00:39 UTC 2020
On 18/03/2020 16:52, Sebastian Huber wrote:
> Try to bring all descriptions up to date.  Add cross-references to
> several options.
> Update #3900.
I checked in a slightly updated patch. I added a new option type
"feature-enable" to produce a standard text for the default configuration:
https://git.rtems.org/sebh/rtems-qual.git/commit/?id=f85bb0bbaece4c3be58d3b023fd4d118e2c59030
A good example for the new template is here:
https://docs.rtems.org/branches/master/c-user/config/event-record.html
I will work now on an update of the integer type configuration options:
https://devel.rtems.org/ticket/3901
