[rtems-littlevgl PATCH] Add README
Tue Mar 24 13:49:02 UTC 2020
On Tue, Mar 24, 2020 at 6:22 AM Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> On Tue, Mar 24, 2020, 1:55 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Please add the maintainer info for the package, and/or devel at rtems.org
>> for questions (just in case someone picks this up somehow without
>> RTEMS!)
> Thanks for the review.
> I'll add that in v2 once I get the @rtems address ;)
> Will it be possible to also host it on GitHub?
Yes, talk to Amar about getting that set up, too.
>> On Mon, Mar 23, 2020 at 12:44 PM Vijay Kumar Banerjee
>> >  README.md | 34 ++++++++++++++++++++++++++++++++++
>> >  1 file changed, 34 insertions(+)
>> >  create mode 100644 README.md
>> > diff --git a/README.md b/README.md
>> > new file mode 100644
>> > index 0000000..161e4d9
>> > --- /dev/null
>> > +++ b/README.md
>> > @@ -0,0 +1,34 @@
>> > +RTEMS LittlevGL
>> > +Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library using
>> > +waf with the required settings for running it with rtems. The lvgl drivers are
>> > +adapted to the BSD framebuffer and hence requires the latest rtems-libbsd build.
>> > +About LittlevGL
>> > +LittlevGL is a lightweight graphics library for embedded GUI applications. It
>> > +can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files that are
>> > +in the top of the rtems-littlevgl directory.
>> > +The documentation is available at:
>> > +https://docs.littlevgl.com/en/html/index.html
>> > +Building and installing rtems-littlevgl
>> > +git clone git://git.rtems.org/packages/rtems-littlevgl.git
>> > +git submodule update
>> > +./waf configure --prefix=/path/to/rtems/5
>> > +./waf build install
>> > +Writing embedded GUI app using rtems-littlevgl
>> > +The rtems-examples repository has a sample lvgl hello world application that can
>> > +be followed for reference on how to write and build an application with lvgl.
>> > +The sample app can be found here:
>> > +https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
>> > 2.21.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
