[rtems-littlevgl PATCH v2 1/2] Add README
Gedare Bloom
gedare at rtems.org
Tue Mar 24 19:29:40 UTC 2020
On Tue, Mar 24, 2020 at 1:09 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> README.md | 47 +++++++++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 47 insertions(+)
> create mode 100644 README.md
> diff --git a/README.md b/README.md
> new file mode 100644
> index 0000000..d0e7b02
> --- /dev/null
> +++ b/README.md
> @@ -0,0 +1,47 @@
> +RTEMS LittlevGL
> +Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library using
> +waf with the required settings for running it with rtems. The lvgl drivers are
> +adapted to the BSD framebuffer and hence requires the latest rtems-libbsd build.
> +About LittlevGL
> +LittlevGL is a lightweight graphics library for embedded GUI applications. It
> +can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files that are
> +in the top of the rtems-littlevgl directory.
> +The documentation is available at:
> +https://docs.littlevgl.com/en/html/index.html
> +Building and installing rtems-littlevgl
> +git clone git://git.rtems.org/packages/rtems-littlevgl.git
> +git submodule update
> +./waf configure --prefix=/path/to/rtems/5
> +./waf build install
> +Writing embedded GUI app using rtems-littlevgl
> +The rtems-examples repository has a sample lvgl hello world application that can +be followed for reference on how to write and build an application with lvgl.
something weird happened here?
fix and push
> +The sample app can be found here:
> +https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
> +Where to discuss questions and ideas?
> +The preferred way of carrying out any discussions or questions is to reach out
> +to the users mailing list users at rtems.org or the devel mailing list
> +devel at rtems.org for more detailed discussions.
> +In any discussions related to rtems-littlevgl, the maintainers can be CC'd by
> +their respective id's given below:
> +Christian Mauderer (christian.mauderer at embedded-brains.de)
> +Vijay Kumar Banerjee (vijay at rtems.org)
> 2.21.1
> devel mailing list
> devel at rtems.org
