[rtems-littlevgl PATCH v2 1/2] Add README
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 24 19:50:50 UTC 2020
On Wed, Mar 25, 2020 at 12:59 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 24, 2020 at 1:09 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >  README.md | 47 +++++++++++++++++++++++++++++++++++++++++++++++
> >  1 file changed, 47 insertions(+)
> >  create mode 100644 README.md
> > diff --git a/README.md b/README.md
> > new file mode 100644
> > index 0000000..d0e7b02
> > --- /dev/null
> > +++ b/README.md
> > @@ -0,0 +1,47 @@
> > +RTEMS LittlevGL
> > +Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library
> using
> > +waf with the required settings for running it with rtems. The lvgl
> drivers are
> > +adapted to the BSD framebuffer and hence requires the latest
> rtems-libbsd build.
> > +About LittlevGL
> > +LittlevGL is a lightweight graphics library for embedded GUI
> applications. It
> > +can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files
> that are
> > +in the top of the rtems-littlevgl directory.
> > +The documentation is available at:
> > +https://docs.littlevgl.com/en/html/index.html
> > +Building and installing rtems-littlevgl
> > +git clone git://git.rtems.org/packages/rtems-littlevgl.git
> > +git submodule update
> > +./waf configure --prefix=/path/to/rtems/5
> > +./waf build install
> > +Writing embedded GUI app using rtems-littlevgl
> > +The rtems-examples repository has a sample lvgl hello world application
> that can +be followed for reference on how to write and build an
> application with lvgl.
> something weird happened here?
> fix and push
> Pushed!
https://git.rtems.org/packages/rtems-littlevgl/commit/?id=9135baf7d2591a907740f30d5ecffb3e77d1f1be
> > +The sample app can be found here:
> > +https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
> > +Where to discuss questions and ideas?
> > +The preferred way of carrying out any discussions or questions is to
> reach out
> > +to the users mailing list users at rtems.org or the devel mailing list
> > +devel at rtems.org for more detailed discussions.
> > +In any discussions related to rtems-littlevgl, the maintainers can be
> CC'd by
> > +their respective id's given below:
> > +Christian Mauderer (christian.mauderer at embedded-brains.de)
> > +Vijay Kumar Banerjee (vijay at rtems.org)
> > 2.21.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200325/fcbbd393/attachment.html>
