Update POSIX compliance guide
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Mar 25 17:05:53 UTC 2020
I will check the musl for a more RTEMS supported implementation.
but will newlib change the implementation??
On Wed, Mar 25, 2020 at 8:26 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Mar 22, 2020 at 2:00 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> I have also checked wordexp.h is completely present in newlib
>> (libc/include)
>> the implementation of the functions wordexp.c and wordfree.c is in
>> (libc/posix)
>> But the compliance status shows not supported.
> I don't see them in libc.a for the sparc:
> lib_a-wordexp.o:
> lib_a-wordfree.o:
> It is not included in RTEMS because the newlib implementation requires
> multiple
> processes. It uses fork() and pipes.
> Maybe MUSCL has an implementation that is embedded friendly but the
> compliance
> guide is correct.
> --joel
>> On Sat, Mar 21, 2020 at 11:31 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Sat, Mar 21, 2020, 8:47 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> Hello everyone
>>>> I went through the POSIX Compliance guide and it showed that
>>>> wcsncasecmp_l () was not supported in wchar.h
>>>> But when I checked newlib it had been implemented in libc/string
>>>> so I think it needs to be updated in the docs.
>>> Thanks for spotting this. I did a spot check and think there were a few
>>> more wc* methods that were not in the spreadsheet. I am going to post a
>>> patch in a bit. Please check it.
>>> Obviously, this is a csv file maintained externally in a spreadsheet. If
>>> you put it in a spreadsheet, you can turn on data filtering based on the
>>> top row. Then you can do "queries" to do things like filter down to what's
>>> in a single header file. Or what's required in one standard but not in
>>> another.
>>> FWIW this turned into a bit of a rat hole. I tried to double check the
>>> newlib git repo and the link on their website is wrong after the upgrade of
>>> sourceware.org. Then checked gdb and it had the same issue. This
>>> resulted in also reporting some leftover cleanup from the recent upgrade of
>>> sourceware.org.
>>>> Thanks
>>>> Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200325/b2d2b2bd/attachment.html>
