Update POSIX compliance guide
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Mar 25 17:59:43 UTC 2020
I went through the implementations in FreeBSD, NetBSD and musl
they all require fork().
So they can't be used by RTEMS.
On Wed, Mar 25, 2020 at 11:17 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Eshan,
> We can work with the newlib community. Some things can be done in
> newlib that are only for RTEMS, while some things we should share with
> others, and still more code may be not useable by RTEMS (e.g., what is
> in sys/linux). It is best to try to make common code available, but if
> some code has to be specialized for RTEMS differently than how it
> works in other systems then we can do that.
> Gedare
> On Wed, Mar 25, 2020 at 11:06 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > I will check the musl for a more RTEMS supported implementation.
> > but will newlib change the implementation??
> > On Wed, Mar 25, 2020 at 8:26 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Sun, Mar 22, 2020 at 2:00 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>> I have also checked wordexp.h is completely present in newlib
> (libc/include)
> >>> the implementation of the functions wordexp.c and wordfree.c is in
> (libc/posix)
> >>> But the compliance status shows not supported.
> >> I don't see them in libc.a for the sparc:
> >> lib_a-wordexp.o:
> >> lib_a-wordfree.o:
> >> It is not included in RTEMS because the newlib implementation requires
> multiple
> >> processes. It uses fork() and pipes.
> >> Maybe MUSCL has an implementation that is embedded friendly but the
> compliance
> >> guide is correct.
> >> --joel
> >>> On Sat, Mar 21, 2020 at 11:31 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>> On Sat, Mar 21, 2020, 8:47 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>>>> Hello everyone
> >>>>> I went through the POSIX Compliance guide and it showed that
> wcsncasecmp_l () was not supported in wchar.h
> >>>>> But when I checked newlib it had been implemented in libc/string
> >>>>> so I think it needs to be updated in the docs.
> >>>> Thanks for spotting this. I did a spot check and think there were a
> few more wc* methods that were not in the spreadsheet. I am going to post a
> patch in a bit. Please check it.
> >>>> Obviously, this is a csv file maintained externally in a spreadsheet.
> If you put it in a spreadsheet, you can turn on data filtering based on the
> top row. Then you can do "queries" to do things like filter down to what's
> in a single header file. Or what's required in one standard but not in
> another.
> >>>> FWIW this turned into a bit of a rat hole. I tried to double check
> the newlib git repo and the link on their website is wrong after the
> upgrade of sourceware.org. Then checked gdb and it had the same issue.
> This resulted in also reporting some leftover cleanup from the recent
> >>>>> Thanks
> >>>>> Eshan
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200325/2d55dbcc/attachment.html>
