GSoC Students: Submit Draft Applications
Anmol Mishra anmol.j2020 at gmail.com
Thu Mar 26 18:57:44 UTC 2020
Hello, I have updated the draft from my dashboard, Please check it, It
should be visible to you now.
Regards
Anmol Mishra
On Thu, Mar 26, 2020 at 4:50 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Students,
> I see several of you have submitted "Draft, shared" in GSoC App. That
> is good, but I also want you to know that you can upload your Final
> PDF multiple times before the deadline, so don't be afraid to do that
> early and often.
> Gedare
> On Fri, Mar 20, 2020 at 4:24 PM Gedare Bloom <gedare at rtems.org> wrote:
> > Hello Aspiring Students,
> > I wanted to let you know that you can submit and revise your
> > application including your "Final" proposal as many times as you like
> > in the Official website, and that you should do so now and update it
> > periodically until the deadline. If you don't submit it then you can't
> > get picked. "Final" is not final. :)
> > Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/db9f5933/attachment.html>
