[PATCH 2/2] user: Use consitent Hello World spelling
Sebastian Huber
Fri Mar 27 08:02:59 UTC 2020
user/exe/initialization.rst | 2 +-
user/start/app.rst | 4 ++--
user/tools/boot-image.rst | 2 +-
user/tools/tester.rst | 2 +-
4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
index cfe39d6..6c9d657 100644
--- a/user/exe/initialization.rst
+++ b/user/exe/initialization.rst
@@ -82,7 +82,7 @@ system is based on the `FreeBSD SYSINT Framework
initialization is performed before multitasking is started.
The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the registered
-handlers. The following shows the initialization handlers for the *hello world*
+handlers. The following shows the initialization handlers for the Hello World
sample application in the RTEMS kernel's testsuite::
.. code-block:: none
diff --git a/user/start/app.rst b/user/start/app.rst
index a0c4a04..ac3c064 100644
--- a/user/start/app.rst
+++ b/user/start/app.rst
@@ -10,7 +10,7 @@ Build Your Application
You tested a BSP in the previous section. We built the ``erc32`` BSP
and it is installed under :file:`$HOME/quick-start/rtems/5`.
-We will now create a simple hello world application with a Git
+We will now create a simple Hello World application with a Git
repository and using the `Waf <https://waf.io>`_ build system.
The application is be created in :file:`$HOME/quick-start/app/hello`.
@@ -77,7 +77,7 @@ settings:
#include <rtems/confdefs.h>
-Create the *hello world* application source file. Using an editor
+Create the Hello World application source file. Using an editor
create :file:`hello.c` and copy the follow code:
.. code-block:: c
diff --git a/user/tools/boot-image.rst b/user/tools/boot-image.rst
index 8e8f63d..2d6cad9 100644
--- a/user/tools/boot-image.rst
+++ b/user/tools/boot-image.rst
@@ -315,7 +315,7 @@ Create a disk image from a built U-Boot sandbox:
Finished
Cleaning up
-Create a 32M byte SD card image with the testsuite's hello world
+Create a 32M byte SD card image with the testsuite's Hello World
executable (``hello.exe``):
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index c3c3fe2..e3a21c9 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -95,7 +95,7 @@ perform a pre-test command to covert the executable to a suitable format for
your target.
Before running all the tests it is a good idea to run the ``hello`` test. The
-``hello`` test is an RTEMS version of the classic "Hello World" example and
+``hello`` test is an RTEMS version of the classic Hello World example and
running it shows you have a working tool chain and build of RTEMS ready to run
the tests. Using the run with the ERC32 BSP the command is:
2.16.4
