[PATCH 2/2] user: Use consitent Hello World spelling
Fri Mar 27 15:40:56 UTC 2020
ok, maybe we also want to have a Hello World glossary item?
On Fri, Mar 27, 2020 at 2:03 AM Sebastian Huber
>  user/exe/initialization.rst | 2 +-
>  user/start/app.rst          | 4 ++--
>  user/tools/boot-image.rst   | 2 +-
>  user/tools/tester.rst       | 2 +-
>  4 files changed, 5 insertions(+), 5 deletions(-)
> diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
> index cfe39d6..6c9d657 100644
> --- a/user/exe/initialization.rst
> +++ b/user/exe/initialization.rst
> @@ -82,7 +82,7 @@ system is based on the `FreeBSD SYSINT Framework
>  initialization is performed before multitasking is started.
>  The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the registered
> -handlers. The following shows the initialization handlers for the *hello world*
> +handlers. The following shows the initialization handlers for the Hello World
>  sample application in the RTEMS kernel's testsuite::
>  .. code-block:: none
> diff --git a/user/start/app.rst b/user/start/app.rst
> index a0c4a04..ac3c064 100644
> --- a/user/start/app.rst
> +++ b/user/start/app.rst
> @@ -10,7 +10,7 @@ Build Your Application
>  You tested a BSP in the previous section.  We built the ``erc32`` BSP
>  and it is installed under :file:`$HOME/quick-start/rtems/5`.
> -We will now create a simple hello world application with a Git
> +We will now create a simple Hello World application with a Git
>  repository and using the `Waf <https://waf.io>`_ build system.
>  The application is be created in :file:`$HOME/quick-start/app/hello`.
> @@ -77,7 +77,7 @@ settings:
>      #include <rtems/confdefs.h>
> -Create the *hello world* application source file. Using an editor
> +Create the Hello World application source file. Using an editor
>  create :file:`hello.c` and copy the follow code:
>  .. code-block:: c
> diff --git a/user/tools/boot-image.rst b/user/tools/boot-image.rst
> index 8e8f63d..2d6cad9 100644
> --- a/user/tools/boot-image.rst
> +++ b/user/tools/boot-image.rst
> @@ -315,7 +315,7 @@ Create a disk image from a built U-Boot sandbox:
>    Finished
>    Cleaning up
> -Create a 32M byte SD card image with the testsuite's hello world
> +Create a 32M byte SD card image with the testsuite's Hello World
>  executable (``hello.exe``):
> diff --git a/user/tools/tester.rst b/user/tools/tester.rst
> index c3c3fe2..e3a21c9 100644
> --- a/user/tools/tester.rst
> +++ b/user/tools/tester.rst
> @@ -95,7 +95,7 @@ perform a pre-test command to covert the executable to a suitable format for
>  your target.
>  Before running all the tests it is a good idea to run the ``hello`` test. The
> -``hello`` test is an RTEMS version of the classic "Hello World" example and
> +``hello`` test is an RTEMS version of the classic Hello World example and
>  running it shows you have a working tool chain and build of RTEMS ready to run
>  the tests. Using the run with the ERC32 BSP the command is:
> 2.16.4
> devel mailing list
> devel at rtems.org
