Ran clang
Fri Mar 27 15:39:25 UTC 2020
This appears to be a pretty standard llvm/clang build for a host system.
There are two parts to consider:
* Using the host tools over RTEMS
* Using cross-compiler tools over RTEMS
For analyzer I don't think the cross-target is a problem but I'm not really
sure. That should be understood before pushing further. My understanding
though is that most of the analyzers run on the LLVM IR, so the backend is
irrelevant.
Gedare
On Fri, Mar 27, 2020 at 12:16 AM suyash singh <suyashsingh234 at gmail.com>
wrote:
> I have run clang. I faced multiple issues on the way due to incomplete
> documentation for clang and llvm. So I wrote all the steps to build them
> here
> https://github.com/suyashsingh234/rtems-notes/blob/master/README.md
> [image: image.png]
> [image: image.png]
> Next I will run scan-build and scan-view on a test file.
> https://docs.google.com/document/d/1OerM8Iix7PbDUCyb_J_KEzcMgLbvdqxd4FnK_BqI7XI/edit
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/87913035/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/87913035/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/87913035/attachment-0003.png>
