Ran clang
    Joel Sherrill
    joel at rtems.org
    Fri Mar 27 16:06:43 UTC 2020
On Fri, Mar 27, 2020 at 10:39 AM Gedare Bloom <gedare at rtems.org> wrote:
> This appears to be a pretty standard llvm/clang build for a host system.
> There are two parts to consider:
> * Using the host tools over RTEMS
> * Using cross-compiler tools over RTEMS
> For analyzer I don't think the cross-target is a problem but I'm not
> really sure. That should be understood before pushing further. My
> understanding though is that most of the analyzers run on the LLVM IR, so
> the backend is irrelevant.
I think the RISC-V and SPARC  have BSPs that can be built with clang.
clang/llvm has a package in the RSB. I would recommend building llvm using
the RSB and then building the supported BSPs.
That is a more solid base to use for analysis. Building RTEMS with the
native compiler is hopeless (tilting at windmills).
Also gcc 10 has improved analysis (
https://developers.redhat.com/blog/2020/03/26/static-analysis-in-gcc-10/).
I would like to see support for using either for static analysis.
Supporting >1 open source/free tool for static analysis before fixing
anything is important (to me). This is already built by the rtems6 RSB
toolchain. When that builds anyway -- it tracks the tools head. :)
Your project should include any additions to the RSB (if needed) and
documenting use of the analyzers. If there is a technique to annotate
source to avoid false positives or deliberate violations, your project
should document that also
> Gedare
> On Fri, Mar 27, 2020 at 12:16 AM suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> I have run clang. I faced multiple issues on the way due to incomplete
>> documentation for clang and llvm. So I wrote all the steps to build them
>> here
>> https://github.com/suyashsingh234/rtems-notes/blob/master/README.md
>> [image: image.png]
>> [image: image.png]
>> Next I will run scan-build and scan-view on a test file.
>> https://docs.google.com/document/d/1OerM8Iix7PbDUCyb_J_KEzcMgLbvdqxd4FnK_BqI7XI/edit
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/75f61e51/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/75f61e51/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/75f61e51/attachment-0003.png>
