[PATCH 1/2] user: Provide a user fiendly configuration
Gedare Bloom
gedare at rtems.org
Fri Mar 27 15:40:00 UTC 2020
That's good it should reduce startup problems.
On Fri, Mar 27, 2020 at 2:03 AM Sebastian Huber
> user/start/app.rst | 8 ++++----
> 1 file changed, 4 insertions(+), 4 deletions(-)
> diff --git a/user/start/app.rst b/user/start/app.rst
> index 98fb284..a0c4a04 100644
> --- a/user/start/app.rst
> +++ b/user/start/app.rst
> @@ -64,14 +64,14 @@ settings:
> * Simple RTEMS configuration
> - #include <rtems.h>
> - #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> + #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> - #define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> + #define CONFIGURE_UNLIMITED_OBJECTS
> + #define CONFIGURE_UNIFIED_WORK_AREAS
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> - #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_INIT
> 2.16.4
> devel mailing list
> devel at rtems.org
