[PATCH 2/2] user: Use consitent Hello World spelling
Fri Mar 27 17:00:28 UTC 2020
On Fri, Mar 27, 2020 at 10:59 AM Joel Sherrill <joel at rtems.org> wrote:
> Good idea Gedare.
> And consitent should be consistent.
I wasn't going to complain about typos in the commit message :)
There's another typo in the other one too.
> On Fri, Mar 27, 2020 at 10:41 AM Gedare Bloom <gedare at rtems.org> wrote:
>> ok, maybe we also want to have a Hello World glossary item?
>> On Fri, Mar 27, 2020 at 2:03 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> >  user/exe/initialization.rst | 2 +-
>> >  user/start/app.rst          | 4 ++--
>> >  user/tools/boot-image.rst   | 2 +-
>> >  user/tools/tester.rst       | 2 +-
>> >  4 files changed, 5 insertions(+), 5 deletions(-)
>> > diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
>> > index cfe39d6..6c9d657 100644
>> > --- a/user/exe/initialization.rst
>> > +++ b/user/exe/initialization.rst
>> > @@ -82,7 +82,7 @@ system is based on the `FreeBSD SYSINT Framework
>> >  initialization is performed before multitasking is started.
>> >  The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the registered
>> > -handlers. The following shows the initialization handlers for the *hello world*
>> > +handlers. The following shows the initialization handlers for the Hello World
>> >  sample application in the RTEMS kernel's testsuite::
>> >  .. code-block:: none
>> > diff --git a/user/start/app.rst b/user/start/app.rst
>> > index a0c4a04..ac3c064 100644
>> > --- a/user/start/app.rst
>> > +++ b/user/start/app.rst
>> > @@ -10,7 +10,7 @@ Build Your Application
>> >  You tested a BSP in the previous section.  We built the ``erc32`` BSP
>> >  and it is installed under :file:`$HOME/quick-start/rtems/5`.
>> > -We will now create a simple hello world application with a Git
>> > +We will now create a simple Hello World application with a Git
>> >  repository and using the `Waf <https://waf.io>`_ build system.
>> >  The application is be created in :file:`$HOME/quick-start/app/hello`.
>> > @@ -77,7 +77,7 @@ settings:
>> >      #include <rtems/confdefs.h>
>> > -Create the *hello world* application source file. Using an editor
>> > +Create the Hello World application source file. Using an editor
>> >  create :file:`hello.c` and copy the follow code:
>> >  .. code-block:: c
>> > diff --git a/user/tools/boot-image.rst b/user/tools/boot-image.rst
>> > index 8e8f63d..2d6cad9 100644
>> > --- a/user/tools/boot-image.rst
>> > +++ b/user/tools/boot-image.rst
>> > @@ -315,7 +315,7 @@ Create a disk image from a built U-Boot sandbox:
>> >    Finished
>> >    Cleaning up
>> > -Create a 32M byte SD card image with the testsuite's hello world
>> > +Create a 32M byte SD card image with the testsuite's Hello World
>> >  executable (``hello.exe``):
>> > diff --git a/user/tools/tester.rst b/user/tools/tester.rst
>> > index c3c3fe2..e3a21c9 100644
>> > --- a/user/tools/tester.rst
>> > +++ b/user/tools/tester.rst
>> > @@ -95,7 +95,7 @@ perform a pre-test command to covert the executable to a suitable format for
>> >  your target.
>> >  Before running all the tests it is a good idea to run the ``hello`` test. The
>> > -``hello`` test is an RTEMS version of the classic "Hello World" example and
>> > +``hello`` test is an RTEMS version of the classic Hello World example and
>> >  running it shows you have a working tool chain and build of RTEMS ready to run
>> >  the tests. Using the run with the ERC32 BSP the command is:
>> > 2.16.4
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
