[PATCH 2/2] user: Use consitent Hello World spelling
Fri Mar 27 16:58:48 UTC 2020
Good idea Gedare.
And consitent should be consistent.
On Fri, Mar 27, 2020 at 10:41 AM Gedare Bloom <gedare at rtems.org> wrote:
> ok, maybe we also want to have a Hello World glossary item?
> On Fri, Mar 27, 2020 at 2:03 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> >  user/exe/initialization.rst | 2 +-
> >  user/start/app.rst          | 4 ++--
> >  user/tools/boot-image.rst   | 2 +-
> >  user/tools/tester.rst       | 2 +-
> >  4 files changed, 5 insertions(+), 5 deletions(-)
> > diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
> > index cfe39d6..6c9d657 100644
> > --- a/user/exe/initialization.rst
> > +++ b/user/exe/initialization.rst
> > @@ -82,7 +82,7 @@ system is based on the `FreeBSD SYSINT Framework
> >  initialization is performed before multitasking is started.
> >  The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the
> registered
> > -handlers. The following shows the initialization handlers for the
> *hello world*
> > +handlers. The following shows the initialization handlers for the Hello
> World
> >  sample application in the RTEMS kernel's testsuite::
> >  .. code-block:: none
> > diff --git a/user/start/app.rst b/user/start/app.rst
> > index a0c4a04..ac3c064 100644
> > --- a/user/start/app.rst
> > +++ b/user/start/app.rst
> > @@ -10,7 +10,7 @@ Build Your Application
> >  You tested a BSP in the previous section.  We built the ``erc32`` BSP
> >  and it is installed under :file:`$HOME/quick-start/rtems/5`.
> > -We will now create a simple hello world application with a Git
> > +We will now create a simple Hello World application with a Git
> >  repository and using the `Waf <https://waf.io>`_ build system.
> >  The application is be created in :file:`$HOME/quick-start/app/hello`.
> > @@ -77,7 +77,7 @@ settings:
> >      #include <rtems/confdefs.h>
> > -Create the *hello world* application source file. Using an editor
> > +Create the Hello World application source file. Using an editor
> >  create :file:`hello.c` and copy the follow code:
> >  .. code-block:: c
> > diff --git a/user/tools/boot-image.rst b/user/tools/boot-image.rst
> > index 8e8f63d..2d6cad9 100644
> > --- a/user/tools/boot-image.rst
> > +++ b/user/tools/boot-image.rst
> > @@ -315,7 +315,7 @@ Create a disk image from a built U-Boot sandbox:
> >    Finished
> >    Cleaning up
> > -Create a 32M byte SD card image with the testsuite's hello world
> > +Create a 32M byte SD card image with the testsuite's Hello World
> >  executable (``hello.exe``):
> > diff --git a/user/tools/tester.rst b/user/tools/tester.rst
> > index c3c3fe2..e3a21c9 100644
> > --- a/user/tools/tester.rst
> > +++ b/user/tools/tester.rst
> > @@ -95,7 +95,7 @@ perform a pre-test command to covert the executable to
> a suitable format for
> >  your target.
> >  Before running all the tests it is a good idea to run the ``hello``
> test. The
> > -``hello`` test is an RTEMS version of the classic "Hello World" example
> and
> > +``hello`` test is an RTEMS version of the classic Hello World example
> and
> >  running it shows you have a working tool chain and build of RTEMS ready
> to run
> >  the tests. Using the run with the ERC32 BSP the command is:
> > 2.16.4
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/50a19f0f/attachment.html>
