Ran clang
suyash singh
suyashsingh234 at gmail.com
Fri Mar 27 17:19:12 UTC 2020
On Fri, Mar 27, 2020 at 9:36 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 27, 2020 at 10:39 AM Gedare Bloom <gedare at rtems.org> wrote:
>> This appears to be a pretty standard llvm/clang build for a host system.
>> There are two parts to consider:
>> * Using the host tools over RTEMS
>> * Using cross-compiler tools over RTEMS
>> For analyzer I don't think the cross-target is a problem but I'm not
>> really sure. That should be understood before pushing further. My
>> understanding though is that most of the analyzers run on the LLVM IR, so
>> the backend is irrelevant.
By cross compiler tools do you mean the Clang Static Analyzer should work
on all hosts after building only once?
> I think the RISC-V and SPARC have BSPs that can be built with clang.
> clang/llvm has a package in the RSB. I would recommend building llvm using
> the RSB and then building the supported BSPs.
> That is a more solid base to use for analysis. Building RTEMS with the
> native compiler is hopeless (tilting at windmills).
> Also gcc 10 has improved analysis (
> https://developers.redhat.com/blog/2020/03/26/static-analysis-in-gcc-10/).
> I would like to see support for using either for static analysis.
> Supporting >1 open source/free tool for static analysis before fixing
> anything is important (to me). This is already built by the rtems6 RSB
> toolchain. When that builds anyway -- it tracks the tools head. :)
> Your project should include any additions to the RSB (if needed) and
> documenting use of the analyzers. If there is a technique to annotate
> source to avoid false positives or deliberate violations, your project
> should document that also
Do you mean the RSB can already build Clang Static Analyzer and
UBSan?
So build clang/llvm and then build BSPs for analysis?
Do you mean adding both gcc 10 and clang static analyzer in RTEMS?
What is already built by rtems6 RSB toolchain?
UBSan needs code to be compiled. Will it be a problem?
Also I am quoting from clang mailing list
As of now we only analyze code that compiles without errors to begin
> with. This does force us to have some amount of interaction with the
> build system.
What are your problems with scan-build though? Is it somehow not working
> for your build system? RTEMS looks like it has a plain old Makefile; as
> long as it respects environment variables CC and CXX, "scan-build make"
> should work just fine
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/fdf9c229/attachment.html>
