[PATCH 1/2] bsp/raspberrypi: Fix build warnings.
Sat Mar 28 16:10:43 UTC 2020
This looks ok. UNLESS we have an RTEMS specific inttypes.h format specifier
for vector.
I don't recall where those are defined or documented. :(
On Sat, Mar 28, 2020, 5:50 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> 1) _Memory_Initialize makes pointer from integer w
> ithout a cast.
> 2) printf format error, expects %u but %lu provided.
>  bsps/arm/raspberrypi/irq/irq.c             | 2 +-
>  bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
>  2 files changed, 3 insertions(+), 1 deletion(-)
> diff --git a/bsps/arm/raspberrypi/irq/irq.c
> b/bsps/arm/raspberrypi/irq/irq.c
> index 9e1bcfc1bc..73dcad298f 100644
> --- a/bsps/arm/raspberrypi/irq/irq.c
> +++ b/bsps/arm/raspberrypi/irq/irq.c
> @@ -157,7 +157,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number
> vector)
>  void bsp_interrupt_handler_default(rtems_vector_number vector)
> -    printk("spurious interrupt: %lu\n", vector);
> +    printk("spurious interrupt: %u\n", vector);
>  rtems_status_code bsp_interrupt_facility_initialize(void)
> diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c
> b/bsps/arm/raspberrypi/start/bspstarthooks.c
> index fd6aa53059..eb6546db1c 100644
> --- a/bsps/arm/raspberrypi/start/bspstarthooks.c
> +++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
> @@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
>    _Memory_Initialize(
>      &_Memory_Areas[0],
> +    (void *)
>  raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
> +    (void *)
>  raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200328/62aded20/attachment.html>
