[PATCH 1/2] bsp/raspberrypi: Fix build warnings.
Gedare Bloom
gedare at rtems.org
Sat Mar 28 23:47:03 UTC 2020
On Sat, Mar 28, 2020 at 10:11 AM Joel Sherrill <joel at rtems.org> wrote:
> This looks ok. UNLESS we have an RTEMS specific inttypes.h format specifier for vector.
> I don't recall where those are defined or documented. :(
Maybe we ought to, but this should never be an lu anyway.
> On Sat, Mar 28, 2020, 5:50 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>> 1) _Memory_Initialize makes pointer from integer w
>> ithout a cast.
>> 2) printf format error, expects %u but %lu provided.
>> bsps/arm/raspberrypi/irq/irq.c | 2 +-
>> bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
>> 2 files changed, 3 insertions(+), 1 deletion(-)
>> diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
>> index 9e1bcfc1bc..73dcad298f 100644
>> --- a/bsps/arm/raspberrypi/irq/irq.c
>> +++ b/bsps/arm/raspberrypi/irq/irq.c
>> @@ -157,7 +157,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
>> void bsp_interrupt_handler_default(rtems_vector_number vector)
>> - printk("spurious interrupt: %lu\n", vector);
>> + printk("spurious interrupt: %u\n", vector);
>> rtems_status_code bsp_interrupt_facility_initialize(void)
>> diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c b/bsps/arm/raspberrypi/start/bspstarthooks.c
>> index fd6aa53059..eb6546db1c 100644
>> --- a/bsps/arm/raspberrypi/start/bspstarthooks.c
>> +++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
>> @@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
>> _Memory_Initialize(
>> &_Memory_Areas[0],
>> + (void *)
>> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
>> + (void *)
>> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
>> 2.17.1
> devel mailing list
> devel at rtems.org
