[PATCH] user/gsoc: GSoC Getting Started Instructions
Niteesh G. S.
niteesh.gs at gmail.com
Sat Mar 28 18:47:39 UTC 2020
We have an Installation chapter under the User manual
https://docs.rtems.org/branches/master/user/installation/index.html
But it isn't detailed enough like the quick start guide. IMO it is the
right place to add detailed instructions. It already has important
information for a good setup like sandboxing, differences between a release
and dev. version, host toolchain setup and more.
Should we move all the details from quick-start chapter to the installation
chapter and make the quick start guide simple enough for a
student to begin with.
We could add a subsection about GSoC under quick-start and ask the students
to refer to the quick-start chapter.
Thank you,
Niteesh.
On Mon, Mar 23, 2020 at 8:29 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Mar 23, 2020 at 3:35 AM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> > On Mon, Mar 23, 2020 at 11:58 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 23/03/2020 06:59, Niteesh G. S. wrote:
> >>> From here on I would prefer references to the existing documentation
> >>> with any GSoC details list here. I would prefer we avoid duplicating
> >>> prefix, sources and building anywhere in the documentaion as it will
> >>> only confuse search engines, normal users and GSoC students. The Quick
> >>> Start Guide has taken a long time to get to where it is. If there is
> >>> something in the Quick Start guide that needs fixing please let me
> know.
> >> I had this discussion with Gedare. We felt it would be nice to have all
> the
> >> instructions in once place instead of referencing them. It would make it
> >> easier for newcomers and students to follow.
> >> Maybe I'll use the same prefix as in the Quick Start guide but have all
> the
> >> instructions here.
> >> In case the Quick Start section is difficult to follow for newcomers
> and students, then the Quick Start should be fixed. I am also not in favour
> of duplicating content and prefer references. All this duplication makes it
> very hard to maintain the documentation. I am sorry if that this causes
> some extra work for you.
> > By difficult to follow I mean that it is just too much information for a
> student who just wants
> > to set up an initial functioning development environment. But, also
> having all that information
> > is important to get an understanding of the process that happens in the
> background.
> The original intent of GSoC Getting Started Tutorial was to provide
> simplified instructions to get into some baseline development
> environment. Over time with the evolution of RSB and recent revamping
> of the Quick Start, I think perhaps we do have the opportunity to
> merge these instructions somewhat. However, there are extra details
> in Quick Start that are not necessary for getting into a development
> environment asap. Perhaps provide a "GSoC Getting Started" as a
> subchapter in the Quick Start that points to all the relevant sections
> with explicit instructions (use erc32, use master branch, etc.) and
> then the "proof" request along with contacting the ML after reviewing
> open project. The last part is still only relevant to GSoC students
> (or students in general that just want to get started).
> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200329/b3a8bba2/attachment-0001.html>
