[PATCH] user/gsoc: GSoC Getting Started Instructions
Sebastian Huber
Mon Mar 30 05:47:51 UTC 2020
On 28/03/2020 19:47, Niteesh G. S. wrote:
> We have an Installation chapter under the User manual
> https://docs.rtems.org/branches/master/user/installation/index.html
> But it isn't detailed enough like the quick start guide. IMO it is the
> right place to add detailed instructions. It already has important
> information for a good setup like sandboxing, differences between a
> release and dev. version, host toolchain setup and more.
> Should we move all the details from quick-start chapter to the
> installation chapter and make the quick start guide simple enough for a
> student to begin with.
> We could add a subsection about GSoC under quick-start and ask the
> students to refer to the quick-start chapter.
We should really try to consolidate the documentation. Having mostly the
same stuff in different places is a maintenance problem. The intention
of the Quick Start chapter is to get started quickly step by step on a
simulator platform which is able to run the RTEMS test suite properly.
You should be able to use it as a template for your desired target
system. Getting started on a simulator platform should be the right
thing for a GSoC student?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/489a9b0f/attachment-0001.html>
