Libbsd Undefined References When Running FACE Conformance Tests
Mon Mar 30 14:27:36 UTC 2020
On 30/03/2020 15:33, Joel Sherrill wrote:
> + Should Jeff be testing using the 5-freebsd-12 branch?
The 5-freebsd-12 branch is intended for production systems.
> + Why isn't the master in sync enough to pass this simple test?
You probably use the wrong options to link the test. You need to enable
the linker garbage collection.
If you need a certain feature, then you should add test cases for this.
> + What's the relationship between the master and 5-freebsd-12?
https://github.com/RTEMS/rtems-libbsd#branches
