Libbsd Undefined References When Running FACE Conformance Tests
Joel Sherrill
joel at rtems.org
Mon Mar 30 14:37:57 UTC 2020
On Mon, Mar 30, 2020 at 9:27 AM Sebastian Huber <
> On 30/03/2020 15:33, Joel Sherrill wrote:
> > + Should Jeff be testing using the 5-freebsd-12 branch?
> The 5-freebsd-12 branch is intended for production systems.
OK. Then Jeff made a mistake using the master.
> > + Why isn't the master in sync enough to pass this simple test?
> You probably use the wrong options to link the test. You need to enable
> the linker garbage collection.
> If you need a certain feature, then you should add test cases for this.
These weren't odd features. This was all the methods in the if.h header file
plus socket, pselect(), and a lot more.
> > + What's the relationship between the master and 5-freebsd-12?
> https://github.com/RTEMS/rtems-libbsd#branches
That doesn't answer whether the master simply tracks FreeBSD or whether
it includes the RTEMS modifications. If the latter, it is current broken.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/b957bdcd/attachment.html>
