Libbsd Undefined References When Running FACE Conformance Tests
Joel Sherrill
joel at rtems.org
Mon Mar 30 15:18:45 UTC 2020
On Mon, Mar 30, 2020 at 9:42 AM Sebastian Huber <
> On 30/03/2020 16:37, Joel Sherrill wrote:
> > + What's the relationship between the master and 5-freebsd-12?
>> https://github.com/RTEMS/rtems-libbsd#branches
> That doesn't answer whether the master simply tracks FreeBSD or whether
> it includes the RTEMS modifications.
> Hm, to me it is obvious that all branches contain RTEMS modifications.
> If the latter, it is current broken.
> Did you try it with the linker garbage collection enabled?
Not yet but shouldn't all code resolve?
This distinctly looks like code which hasn't been touched to address some
VM adaption.
/home/mayes/dev/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:
/home/mayes/rtems-arm/arm-rtems5/xilinx_zynq_a9_qemu/lib/libbsd.a(uipc_mbuf.c.1
8.o): in function `m_unmappedtouio':
/home/mayes/dev/rtems-libbsd/build/arm-rtems5-xilinx_zynq_a9_qemu-default/../..
/freebsd/sys/kern/uipc_mbuf.c:1813: undefined reference to `PHYS_TO_VM_PAGE'
/freebsd/sys/kern/uipc_mbuf.c:1814: undefined reference to
`uiomove_fromphys'
collect2: error: ld returned 1 exit status
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/a34e551d/attachment.html>
