Libbsd Undefined References When Running FACE Conformance Tests
Sebastian Huber
Mon Mar 30 16:05:34 UTC 2020
On 30/03/2020 17:18, Joel Sherrill wrote:
> On Mon, Mar 30, 2020 at 9:42 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 30/03/2020 16:37, Joel Sherrill wrote:
>> > + What's the relationship between the master and 5-freebsd-12?
>> https://github.com/RTEMS/rtems-libbsd#branches
>> That doesn't answer whether the master simply tracks FreeBSD or
>> whether
>> it includes the RTEMS modifications.
> Hm, to me it is obvious that all branches contain RTEMS modifications.
>> If the latter, it is current broken.
> Did you try it with the linker garbage collection enabled?
> Not yet but shouldn't all code resolve?
No, using the linker garbage collection is mandatory from my point of
view. It is important to reduce the code size. Also all libbsd reference
BSPs enable it, so all testing is done with the linker garbage
collection enabled.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/6009c634/attachment.html>
