Traceability from specification to source code?
Gedare Bloom
gedare at rtems.org
Mon Mar 30 16:17:53 UTC 2020
On Mon, Mar 30, 2020 at 8:18 AM Sebastian Huber
> Hello,
> I started with the specification of RTEMS and created the first
> specification items (the application configuration options):
> https://git.rtems.org/sebh/rtems-qual.git/tree/spec/acfg/opt
> For the RTEMS Qualification project we need traceability from the
> specification to the source code and vice versa. For example, there
> should be a link from
> https://git.rtems.org/sebh/rtems-qual.git/tree/spec/acfg/opt/RTEMS-ACFG-OPT-MAXBARRIERS.yml
> to
> https://git.rtems.org/rtems/tree/cpukit/include/rtems/confdefs/objectsclassic.h#n86
> and
> https://git.rtems.org/rtems/tree/cpukit/rtems/src/barrier.c
> To avoid redundancy we should store only one link direction (either from
> source code to requirement or from requirement to source code). A tool
> should scan everything and generate the bidirectional links.
> The question is now where do we want to place the links? We can place
> them in the specification items or the source code.
> In the specification item it could be something like this:
> refs:
> - repository: rtems
> source: cpukit/rtems/src/barrier.c
> lines:
> - [42, 47]
> hash: 8gsKsqCCY-PEXVGihoUMEk_q2YIGyWuGlPsMTA5v_jI=
> attribute: appl-config-option-default-value
> - repository: rtems
> source: include/rtems/confdefs/objectsclassic.h
> lines:
> - [49, 51]
> hash: bSf7xgvXVpy1u_mxP7Fk8qCHwxGCpkc9LrwgT9RzWSY=
> The hash covers the referenced content, e.g. here specified by a line
> range (there could be more means, e.g. regular expressions for begin and
> end markers). If the source code changes in this area, the reference is
> invalidated.
> Pros:
> * No need to modify the sources.
> Cons:
> * Requirements are invisible in the sources.
> * Writing the links is tedious.
> In the sources it could be something like this:
> /* $satisfy{RTEMS-ACFG-OPT-MAXBARRIERS} */
> #if CONFIGURE_MAXIMUM_BARRIERS > 0
> #include <rtems/rtems/barrierdata.h>
> #endif
> /* $satisfy{RTEMS-ACFG-OPT-MAXBARRIERS:appl-config-option-default-value} */
> OBJECTS_INFORMATION_DEFINE_ZERO(
> _Barrier,
> OBJECTS_CLASSIC_API,
> OBJECTS_RTEMS_BARRIERS,
> OBJECTS_NO_STRING_NAME
> The $satisfy could cover the next statement or function. We can use ${
> and $} markers to reference statement blocks. We could also add a line
> count (makes the change tracker much simpler, no need to know what a
> statement is).
> A tool can collect all referenced sources in a defined order and
> generate an overall hash value which is stored in the specification
> item. This allows to track changes relevant for a particular requirement.
> Pros:
> * Requirements are directly visible in the sources.
> * Writing the links is easy, just a comment.
> Cons:
> * We have to modify the sources (with special comments).
> * The tool to track changes in the code could be complex, e.g. needs to
> parse C sources (there are third-party modules to help with this
> https://github.com/eliben/pycparser).
This question is related to
https://lists.rtems.org/pipermail/devel/2019-September/055519.html
about code annotations, and similar discussion raised there applies
here.
> devel mailing list
> devel at rtems.org
