[PATCH v2] bsp/raspberrypi: Fix build warnings.
Gedare Bloom
gedare at rtems.org
Mon Mar 30 22:51:20 UTC 2020
This looks right but I'm not able to try it out.
On Sat, Mar 28, 2020 at 12:24 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> 1) _Memory_Initialize makes pointer from integer
> without a cast.
> 2) printf format error, expects %u but %lu provided.
> bsps/arm/raspberrypi/irq/irq.c | 4 +++-
> bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
> 2 files changed, 5 insertions(+), 1 deletion(-)
> diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
> index 9e1bcfc1bc..835cdf97d9 100644
> --- a/bsps/arm/raspberrypi/irq/irq.c
> +++ b/bsps/arm/raspberrypi/irq/irq.c
> @@ -32,6 +32,8 @@
> #include <rtems/bspIo.h>
> #include <strings.h>
> +#include <rtems/inttypes.h>
> #ifdef RTEMS_SMP
> #include <rtems/score/smp.h>
> #include <rtems/score/smpimpl.h>
> @@ -157,7 +159,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
> void bsp_interrupt_handler_default(rtems_vector_number vector)
> - printk("spurious interrupt: %lu\n", vector);
> + printk("spurious interrupt: %" PRIdrtems_vector_number "\n", vector);
> rtems_status_code bsp_interrupt_facility_initialize(void)
> diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c b/bsps/arm/raspberrypi/start/bspstarthooks.c
> index fd6aa53059..eb6546db1c 100644
> --- a/bsps/arm/raspberrypi/start/bspstarthooks.c
> +++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
> @@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
> _Memory_Initialize(
> &_Memory_Areas[0],
> + (void *)
> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
> + (void *)
> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
> 2.17.1
> devel mailing list
> devel at rtems.org
