[PATCH] Fix typos in rtems-docs-4.11/rsb
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Tue Mar 31 17:16:22 UTC 2020
Hi Gedare,
Apologies as I missed that rsb is moved to user/rsb in the master. After
going
through it, I have found that files:
rsb/hosts.rst
rsb/quick-start.rst
are no longer there in the master branch. However, most of the typos are
still there in other remaining files.
On Tue, Mar 31, 2020 at 9:40 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Mritunjay,
> Are these all fixed already in master branch? these docs moved to
> user/rsb/*
> On Tue, Mar 31, 2020 at 4:22 AM Mritunjay <mritunjaysharma394 at gmail.com>
> wrote:
> > This patch fixes typos encountered while going through the documentation
> > of rtems-docs-4.11/rsb.
> > rsb/configuration.rst | 24 ++++++++++++------------
> > rsb/cross-canadian-cross.rst | 2 +-
> > rsb/hosts.rst | 4 ++--
> > rsb/project-sets.rst | 4 ++--
> > rsb/quick-start.rst | 6 +++---
> > rsb/third-party-packages.rst | 4 ++--
> > 6 files changed, 22 insertions(+), 22 deletions(-)
> > diff --git a/rsb/configuration.rst b/rsb/configuration.rst
> > index 62fc073..bf3dfaa 100644
> > --- a/rsb/configuration.rst
> > +++ b/rsb/configuration.rst
> > @@ -121,12 +121,12 @@ the decompression tool and all other files must be
> in the tar file format.
> > The ``%source`` directive typically supports a single source file tar
> or zip
> > file. The ``set`` command is used to set the URL for a specific source
> > -group. The first set command encoutner is registered and any further set
> > +group. The first set command encounter is registered and any further set
> > commands are ignored. This allows you to define a base standard source
> location
> > and override it in build and architecture specific files. You can also
> add
> > extra source files to a group. This is typically done when a collection
> of
> > source is broken down in a number of smaller files and you require the
> full
> > -package. The source's ``setup`` command must reide in the ``%prep:``
> section
> > +package. The source's ``setup`` command must reside in the ``%prep:``
> section
> > and it unpacks the source code ready to be built.
> > If the source URL references the GitHub API server
> https://api.github.com/ a
> > @@ -180,7 +180,7 @@ errors that can arise.
> > The protocol option lets you set a specific protocol. The ``git://``
> prefix
> > used by the RSB to select a git repository can be removed using *none*
> or
> > -replaced with one of the standard git protcols.
> > +replaced with one of the standard git protocols.
> > CVS
> > @@ -304,7 +304,7 @@ Maps are declared anywhere in the map using the map
> directive::
> > 1. The map is set to ``my-special-map``.
> > -Any macro defintions following a map declaration are placed in that map
> and the
> > +Any macro definitions following a map declaration are placed in that
> map and the
> > default map is ``global`` when loading a file. Maps are selected in
> > configuration files by using the ``%select`` directive::
> > @@ -315,7 +315,7 @@ if present return that value else the ``global`` map
> is used. Any new macros or
> > changes update only the ``global`` map. This may change in future
> releases so
> > please make sure you use the ``override`` attribute.
> > -The macro files specificed on the command line are looked for in the
> > +The macro files specified on the command line are looked for in the
> > ``_configdir`` paths. See <<X1,``_configdir``>> variable for details.
> Included
> > files need to add the ``%{_configdir}`` macro to the start of the file.
> > @@ -494,7 +494,7 @@ To create a private configuration change to a
> suitable directory::
> > and create a ``config`` directory. Here you can add a new configuration
> or
> > build set file. The section 'Adding New Configurations' details how to
> add a
> > -new confguration.
> > +new configuration.
> > New Configurations
> > @@ -597,8 +597,8 @@ source packages based on the outer configuration
> options::
> > The remainder of the script is broken in to the various phases of a
> build. They
> > are:
> > -. Preperation
> > -. Bulding
> > +. Preparation
> > +. Building
> > . Installing, and
> > . Cleaning
> > @@ -748,11 +748,11 @@ To build this you can use something similar to::
> > The build is for a FreeBSD host and the prefix is for user installed
> > packages. In this example I cannot let the source builder perform the
> install
> > -because I never run the RSB with root priviledges so a build set or
> bset tar
> > -file is created. This can then be installed using root privildges.
> > +because I never run the RSB with root privileges so a build set or bset
> tar
> > +file is created. This can then be installed using root privileges.
> > The command also supplies the ``--trace`` option. The output in the log
> file
> > -will contian all the macros.
> > +will contain all the macros.
> > Debugging
> > @@ -1320,7 +1320,7 @@ Do not include a path with the file name. Only the
> basename is required. Files
> > can be searched for from a number of places and having a path conponent
> would
> > create confusion. This does mean files with hashes must be unique.
> > -Downloading of repositories such as git and cvs cannot be checksumed.
> It is
> > +Downloading of repositories such as git and cvs cannot be checksummed.
> It is
> > assumed those protocols and tools manage the state of the files.
> > %echo
> > diff --git a/rsb/cross-canadian-cross.rst b/rsb/cross-canadian-cross.rst
> > index d4fce9e..039c7a7 100644
> > --- a/rsb/cross-canadian-cross.rst
> > +++ b/rsb/cross-canadian-cross.rst
> > @@ -36,7 +36,7 @@ To build the NTP package for RTEMS you enter the RSB
> command::
> > 2. The ``--host`` command is the RTEMS architecture and version.
> > - 3. The BSP is built and installed in the prefix. The arhcitecture
> must match
> > + 3. The BSP is built and installed in the prefix. The architecture
> must match
> > the ``--host`` architecture.
> > .. note: Installing Into Different Directories
> > diff --git a/rsb/hosts.rst b/rsb/hosts.rst
> > index a4226f3..ebcca23 100644
> > --- a/rsb/hosts.rst
> > +++ b/rsb/hosts.rst
> > @@ -14,7 +14,7 @@ new version of a host is known to work and it not
> listed please lets us know.
> > Linux
> > -A number of different Linux distrubutions are known to work. The
> following have
> > +A number of different Linux distributions are known to work. The
> following have
> > been tested and report as working.
> > .. _ArchLinux:
> > @@ -122,7 +122,7 @@ ports::
> > # portinstall --batch devel/mingw32-binutils devel/mingw32-gcc
> > # portinstall --batch devel/mingw32-zlib devel/mingw32-pthreads
> > -The +zlip+ and +pthreads+ ports for MinGW32 are used for builiding a
> Windows
> > +The +zlip+ and +pthreads+ ports for MinGW32 are used for building a
> Windows
> > QEMU.
> > If you are on FreeBSD 10.0 and you have pkgng installed you can use 'pkg
> > diff --git a/rsb/project-sets.rst b/rsb/project-sets.rst
> > index 8abd080..6ca27e7 100644
> > --- a/rsb/project-sets.rst
> > +++ b/rsb/project-sets.rst
> > @@ -159,7 +159,7 @@ tools within that release. If the package is not
> specific to any release the
> > patch can be added closer to the top under the package's name. Patches
> to fix
> > specific tool related issues for a specific architecture should be
> grouped
> > under the specific architecture and only applied when building that
> > -architecture avoiding a patch breaking an uneffected architecture.
> > +architecture avoiding a patch breaking an unaffected architecture.
> > Patches in the RTEMS Tools repository need to be submitted to the
> upstream
> > project. It should not be a clearing house for patches that will not be
> > @@ -169,7 +169,7 @@ Patches are added to a component's name and in the
> ``%prep:`` section the
> > patches can be set up, meaning they are applied to source. The patches
> > are applied in the order they are added. If there is a dependency make
> > sure you order the patches correctly when you add them. You can add any
> > -number of patches and the RSB will handle them efficently.
> > +number of patches and the RSB will handle them efficiently.
> > Patches can have options. These are added before the patch URL. If no
> options
> > are provided the patch's setup default options are used.
> > diff --git a/rsb/quick-start.rst b/rsb/quick-start.rst
> > index f39c0a6..e39a914 100644
> > --- a/rsb/quick-start.rst
> > +++ b/rsb/quick-start.rst
> > @@ -429,7 +429,7 @@ A build set tar file is created by adding
> ``--bset-tar-file`` option to the
> > 3. Creating the build set tar file.
> > You can also suppress installing the files using the ``--no-install``
> > -option. This is useful if your prefix is not accessiable, for example
> when
> > +option. This is useful if your prefix is not accessible, for example
> when
> > building Canadian cross compiled tool sets::
> > $ ../source-builder/sb-set-builder --log=l-sparc.txt \
> > @@ -462,7 +462,7 @@ building Canadian cross compiled tool sets::
> > .. topic:: Items
> > - 1. The option to supressing installing the packages.
> > + 1. The option to suppressing installing the packages.
> > 2. Create the build set tar.
> > @@ -517,7 +517,7 @@ because they are implemented with the configuration
> scripts. The best way to
> > find what is available is to grep the configuration files. for ``with``
> and
> > ``without``.
> > -Following are currentlt available:
> > +Following are currently available:
> > ``--without-rtems``
> > Do not build RTEMS when building an RTEMS build set.
> > diff --git a/rsb/third-party-packages.rst b/rsb/third-party-packages.rst
> > index a43abeb..1ef7c68 100644
> > --- a/rsb/third-party-packages.rst
> > +++ b/rsb/third-party-packages.rst
> > @@ -66,7 +66,7 @@ this may require you asking questions on the package's
> user or development
> > support lists as well as RTEMS's developers list. Your porting effort
> may end
> > up with a patch. RTEMS requires a patch be submitted upstream to the
> project's
> > community as well as RTEMS so it can be added to the RTEMS Tools git
> > -repository. A patch in the RTEMS Tools git reposiitory can then be
> referenced
> > +repository. A patch in the RTEMS Tools git repository can then be
> referenced
> > by an RSB configuration file.
> > A package may create executables, for example NTP normally creates
> executables
> > @@ -75,7 +75,7 @@ when testing the package however they are of limited
> use by RTEMS users because
> > they cannot be directly linked into a user application. Users need to
> link to
> > the functions in these executables or even the executable as a function
> placed
> > in libraries. If the package does not export the code in a suitable
> manner
> > -please contact the project's commuinity and see if you can work them to
> provide
> > +please contact the project's community and see if you can work them to
> provide
> > a way for the code to be exported. This may be difficult because
> exporting
> > internal headers and functions opens the project up to API
> compatibility issues
> > they did not have before. In the simplest case attempting to get the
> code into
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200331/613dbbe5/attachment-0001.html>
