[PATCH] Fix typos in rtems-docs-4.11/rsb
Gedare Bloom
gedare at rtems.org
Tue Mar 31 17:19:18 UTC 2020
Can you send a patch to fix the typos in Master? we can also apply to
4.11, but would like to fix them in master for sure.
On Tue, Mar 31, 2020 at 11:16 AM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> Hi Gedare,
> Apologies as I missed that rsb is moved to user/rsb in the master. After going
> through it, I have found that files:
> rsb/hosts.rst
> rsb/quick-start.rst
> are no longer there in the master branch. However, most of the typos are still there in other remaining files.
> On Tue, Mar 31, 2020 at 9:40 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Mritunjay,
>> Are these all fixed already in master branch? these docs moved to user/rsb/*
>> On Tue, Mar 31, 2020 at 4:22 AM Mritunjay <mritunjaysharma394 at gmail.com> wrote:
>> > This patch fixes typos encountered while going through the documentation
>> > of rtems-docs-4.11/rsb.
>> > rsb/configuration.rst | 24 ++++++++++++------------
>> > rsb/cross-canadian-cross.rst | 2 +-
>> > rsb/hosts.rst | 4 ++--
>> > rsb/project-sets.rst | 4 ++--
>> > rsb/quick-start.rst | 6 +++---
>> > rsb/third-party-packages.rst | 4 ++--
>> > 6 files changed, 22 insertions(+), 22 deletions(-)
>> > diff --git a/rsb/configuration.rst b/rsb/configuration.rst
>> > index 62fc073..bf3dfaa 100644
>> > --- a/rsb/configuration.rst
>> > +++ b/rsb/configuration.rst
>> > @@ -121,12 +121,12 @@ the decompression tool and all other files must be in the tar file format.
>> > The ``%source`` directive typically supports a single source file tar or zip
>> > file. The ``set`` command is used to set the URL for a specific source
>> > -group. The first set command encoutner is registered and any further set
>> > +group. The first set command encounter is registered and any further set
>> > commands are ignored. This allows you to define a base standard source location
>> > and override it in build and architecture specific files. You can also add
>> > extra source files to a group. This is typically done when a collection of
>> > source is broken down in a number of smaller files and you require the full
>> > -package. The source's ``setup`` command must reide in the ``%prep:`` section
>> > +package. The source's ``setup`` command must reside in the ``%prep:`` section
>> > and it unpacks the source code ready to be built.
>> > If the source URL references the GitHub API server https://api.github.com/ a
>> > @@ -180,7 +180,7 @@ errors that can arise.
>> > The protocol option lets you set a specific protocol. The ``git://`` prefix
>> > used by the RSB to select a git repository can be removed using *none* or
>> > -replaced with one of the standard git protcols.
>> > +replaced with one of the standard git protocols.
>> > CVS
>> > @@ -304,7 +304,7 @@ Maps are declared anywhere in the map using the map directive::
>> > 1. The map is set to ``my-special-map``.
>> > -Any macro defintions following a map declaration are placed in that map and the
>> > +Any macro definitions following a map declaration are placed in that map and the
>> > default map is ``global`` when loading a file. Maps are selected in
>> > configuration files by using the ``%select`` directive::
>> > @@ -315,7 +315,7 @@ if present return that value else the ``global`` map is used. Any new macros or
>> > changes update only the ``global`` map. This may change in future releases so
>> > please make sure you use the ``override`` attribute.
>> > -The macro files specificed on the command line are looked for in the
>> > +The macro files specified on the command line are looked for in the
>> > ``_configdir`` paths. See <<X1,``_configdir``>> variable for details. Included
>> > files need to add the ``%{_configdir}`` macro to the start of the file.
>> > @@ -494,7 +494,7 @@ To create a private configuration change to a suitable directory::
>> > and create a ``config`` directory. Here you can add a new configuration or
>> > build set file. The section 'Adding New Configurations' details how to add a
>> > -new confguration.
>> > +new configuration.
>> > New Configurations
>> > @@ -597,8 +597,8 @@ source packages based on the outer configuration options::
>> > The remainder of the script is broken in to the various phases of a build. They
>> > are:
>> > -. Preperation
>> > -. Bulding
>> > +. Preparation
>> > +. Building
>> > . Installing, and
>> > . Cleaning
>> > @@ -748,11 +748,11 @@ To build this you can use something similar to::
>> > The build is for a FreeBSD host and the prefix is for user installed
>> > packages. In this example I cannot let the source builder perform the install
>> > -because I never run the RSB with root priviledges so a build set or bset tar
>> > -file is created. This can then be installed using root privildges.
>> > +because I never run the RSB with root privileges so a build set or bset tar
>> > +file is created. This can then be installed using root privileges.
>> > The command also supplies the ``--trace`` option. The output in the log file
>> > -will contian all the macros.
>> > +will contain all the macros.
>> > Debugging
>> > @@ -1320,7 +1320,7 @@ Do not include a path with the file name. Only the basename is required. Files
>> > can be searched for from a number of places and having a path conponent would
>> > create confusion. This does mean files with hashes must be unique.
>> > -Downloading of repositories such as git and cvs cannot be checksumed. It is
>> > +Downloading of repositories such as git and cvs cannot be checksummed. It is
>> > assumed those protocols and tools manage the state of the files.
>> > %echo
>> > diff --git a/rsb/cross-canadian-cross.rst b/rsb/cross-canadian-cross.rst
>> > index d4fce9e..039c7a7 100644
>> > --- a/rsb/cross-canadian-cross.rst
>> > +++ b/rsb/cross-canadian-cross.rst
>> > @@ -36,7 +36,7 @@ To build the NTP package for RTEMS you enter the RSB command::
>> > 2. The ``--host`` command is the RTEMS architecture and version.
>> > - 3. The BSP is built and installed in the prefix. The arhcitecture must match
>> > + 3. The BSP is built and installed in the prefix. The architecture must match
>> > the ``--host`` architecture.
>> > .. note: Installing Into Different Directories
>> > diff --git a/rsb/hosts.rst b/rsb/hosts.rst
>> > index a4226f3..ebcca23 100644
>> > --- a/rsb/hosts.rst
>> > +++ b/rsb/hosts.rst
>> > @@ -14,7 +14,7 @@ new version of a host is known to work and it not listed please lets us know.
>> > Linux
>> > -A number of different Linux distrubutions are known to work. The following have
>> > +A number of different Linux distributions are known to work. The following have
>> > been tested and report as working.
>> > .. _ArchLinux:
>> > @@ -122,7 +122,7 @@ ports::
>> > # portinstall --batch devel/mingw32-binutils devel/mingw32-gcc
>> > # portinstall --batch devel/mingw32-zlib devel/mingw32-pthreads
>> > -The +zlip+ and +pthreads+ ports for MinGW32 are used for builiding a Windows
>> > +The +zlip+ and +pthreads+ ports for MinGW32 are used for building a Windows
>> > QEMU.
>> > If you are on FreeBSD 10.0 and you have pkgng installed you can use 'pkg
>> > diff --git a/rsb/project-sets.rst b/rsb/project-sets.rst
>> > index 8abd080..6ca27e7 100644
>> > --- a/rsb/project-sets.rst
>> > +++ b/rsb/project-sets.rst
>> > @@ -159,7 +159,7 @@ tools within that release. If the package is not specific to any release the
>> > patch can be added closer to the top under the package's name. Patches to fix
>> > specific tool related issues for a specific architecture should be grouped
>> > under the specific architecture and only applied when building that
>> > -architecture avoiding a patch breaking an uneffected architecture.
>> > +architecture avoiding a patch breaking an unaffected architecture.
>> > Patches in the RTEMS Tools repository need to be submitted to the upstream
>> > project. It should not be a clearing house for patches that will not be
>> > @@ -169,7 +169,7 @@ Patches are added to a component's name and in the ``%prep:`` section the
>> > patches can be set up, meaning they are applied to source. The patches
>> > are applied in the order they are added. If there is a dependency make
>> > sure you order the patches correctly when you add them. You can add any
>> > -number of patches and the RSB will handle them efficently.
>> > +number of patches and the RSB will handle them efficiently.
>> > Patches can have options. These are added before the patch URL. If no options
>> > are provided the patch's setup default options are used.
>> > diff --git a/rsb/quick-start.rst b/rsb/quick-start.rst
>> > index f39c0a6..e39a914 100644
>> > --- a/rsb/quick-start.rst
>> > +++ b/rsb/quick-start.rst
>> > @@ -429,7 +429,7 @@ A build set tar file is created by adding ``--bset-tar-file`` option to the
>> > 3. Creating the build set tar file.
>> > You can also suppress installing the files using the ``--no-install``
>> > -option. This is useful if your prefix is not accessiable, for example when
>> > +option. This is useful if your prefix is not accessible, for example when
>> > building Canadian cross compiled tool sets::
>> > $ ../source-builder/sb-set-builder --log=l-sparc.txt \
>> > @@ -462,7 +462,7 @@ building Canadian cross compiled tool sets::
>> > .. topic:: Items
>> > - 1. The option to supressing installing the packages.
>> > + 1. The option to suppressing installing the packages.
>> > 2. Create the build set tar.
>> > @@ -517,7 +517,7 @@ because they are implemented with the configuration scripts. The best way to
>> > find what is available is to grep the configuration files. for ``with`` and
>> > ``without``.
>> > -Following are currentlt available:
>> > +Following are currently available:
>> > ``--without-rtems``
>> > Do not build RTEMS when building an RTEMS build set.
>> > diff --git a/rsb/third-party-packages.rst b/rsb/third-party-packages.rst
>> > index a43abeb..1ef7c68 100644
>> > --- a/rsb/third-party-packages.rst
>> > +++ b/rsb/third-party-packages.rst
>> > @@ -66,7 +66,7 @@ this may require you asking questions on the package's user or development
>> > support lists as well as RTEMS's developers list. Your porting effort may end
>> > up with a patch. RTEMS requires a patch be submitted upstream to the project's
>> > community as well as RTEMS so it can be added to the RTEMS Tools git
>> > -repository. A patch in the RTEMS Tools git reposiitory can then be referenced
>> > +repository. A patch in the RTEMS Tools git repository can then be referenced
>> > by an RSB configuration file.
>> > A package may create executables, for example NTP normally creates executables
>> > @@ -75,7 +75,7 @@ when testing the package however they are of limited use by RTEMS users because
>> > they cannot be directly linked into a user application. Users need to link to
>> > the functions in these executables or even the executable as a function placed
>> > in libraries. If the package does not export the code in a suitable manner
>> > -please contact the project's commuinity and see if you can work them to provide
>> > +please contact the project's community and see if you can work them to provide
>> > a way for the code to be exported. This may be difficult because exporting
>> > internal headers and functions opens the project up to API compatibility issues
>> > they did not have before. In the simplest case attempting to get the code into
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
