[PATCH] Fix typos in (master)rtems-docs/user/rsb
Mritunjay
mritunjaysharma394 at gmail.com
Tue Mar 31 18:04:20 UTC 2020
user/rsb/configuration.rst | 14 +++++++-------
user/rsb/cross-canadian-cross.rst | 2 +-
user/rsb/project-sets.rst | 2 +-
user/rsb/third-party-packages.rst | 2 +-
4 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
index fc387a1..8c8c87f 100644
--- a/user/rsb/configuration.rst
+++ b/user/rsb/configuration.rst
@@ -181,7 +181,7 @@ errors that can arise.
The protocol option lets you set a specific protocol. The ``git://`` prefix
used by the RSB to select a git repository can be removed using *none* or
-replaced with one of the standard git protcols.
+replaced with one of the standard git protocols.
CVS
@@ -315,7 +315,7 @@ Maps are declared anywhere in the map using the map directive:
1. The map is set to ``my-special-map``.
-Any macro defintions following a map declaration are placed in that map and the
+Any macro definitions following a map declaration are placed in that map and the
default map is ``global`` when loading a file. Maps are selected in
configuration files by using the ``%select`` directive:
@@ -328,7 +328,7 @@ if present return that value else the ``global`` map is used. Any new macros or
changes update only the ``global`` map. This may change in future releases so
please make sure you use the ``override`` attribute.
-The macro files specificed on the command line are looked for in the
+The macro files specified on the command line are looked for in the
``_configdir`` paths. See <<X1,``_configdir``>> variable for details. Included
files need to add the ``%{_configdir}`` macro to the start of the file.
@@ -636,8 +636,8 @@ source packages based on the outer configuration options:
The remainder of the script is broken in to the various phases of a build. They
are:
-. Preperation
-. Bulding
+. Preparation
+. Building
. Installing, and
. Cleaning
@@ -799,8 +799,8 @@ To build this you can use something similar to:
The build is for a FreeBSD host and the prefix is for user installed
packages. In this example I cannot let the source builder perform the install
-because I never run the RSB with root priviledges so a build set or bset tar
-file is created. This can then be installed using root priviledges.
+because I never run the RSB with root privileges so a build set or bset tar
+file is created. This can then be installed using root privileges.
The command also supplies the ``--trace`` option. The output in the log file
will contain all the macros.
diff --git a/user/rsb/cross-canadian-cross.rst b/user/rsb/cross-canadian-cross.rst
index 8eceed3..7ccd6c3 100644
--- a/user/rsb/cross-canadian-cross.rst
+++ b/user/rsb/cross-canadian-cross.rst
@@ -37,7 +37,7 @@ To build the Curl package for RTEMS you enter the RSB command:
2. The ``--host`` command is the RTEMS architecture and version.
- 3. The BSP is built and installed in the prefix. The arhcitecture must match
+ 3. The BSP is built and installed in the prefix. The architecture must match
the ``--host`` architecture.
.. note: Installing Into Different Directories
diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
index 6eb8729..54a3f8e 100644
--- a/user/rsb/project-sets.rst
+++ b/user/rsb/project-sets.rst
@@ -154,7 +154,7 @@ Patches are added to a component's name and in the ``%prep:`` section the
patches can be set up, meaning they are applied to source. The patches are
applied in the order they are added. If there is a dependency make sure you
order the patches correctly when you add them. You can add any number of
-patches and the RSB will handle them efficently.
+patches and the RSB will handle them efficiently.
Patches can have options. These are added before the patch URL. If no options
are provided the patch's setup default options are used.
diff --git a/user/rsb/third-party-packages.rst b/user/rsb/third-party-packages.rst
index 0d9fa81..8610650 100644
--- a/user/rsb/third-party-packages.rst
+++ b/user/rsb/third-party-packages.rst
@@ -133,7 +133,7 @@ A custom RTEMS patch to an executate's source code can turn it into a function
that can be called by the RTEMS shell. Users can call the function in their
executables simulating the running of the package's command. If the package
does not export the code in a suitable manner please contact the project's
-commuinity and see if you can work with them to provide a way for the code to
+community and see if you can work with them to provide a way for the code to
be exported. This may be difficult because exporting internal headers and
functions opens the project up to API compatibility issues they did not have
before. In the simplest case attempting to get the code into a static library
2.17.1
