[PATCH] Fix typos in rtems-docs-4.11/rsb
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue Mar 31 17:19:52 UTC 2020
Yes, will do that.
On Tue, Mar 31, 2020 at 10:49 PM Gedare Bloom <gedare at rtems.org> wrote:
> Can you send a patch to fix the typos in Master? we can also apply to
> 4.11, but would like to fix them in master for sure.
> On Tue, Mar 31, 2020 at 11:16 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > Hi Gedare,
> > Apologies as I missed that rsb is moved to user/rsb in the master. After
> going
> > through it, I have found that files:
> > rsb/hosts.rst
> > rsb/quick-start.rst
> > are no longer there in the master branch. However, most of the typos are
> still there in other remaining files.
> > On Tue, Mar 31, 2020 at 9:40 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Mritunjay,
> >> Are these all fixed already in master branch? these docs moved to
> user/rsb/*
> >> On Tue, Mar 31, 2020 at 4:22 AM Mritunjay <mritunjaysharma394 at gmail.com>
> wrote:
> >> > This patch fixes typos encountered while going through the
> documentation
> >> > of rtems-docs-4.11/rsb.
> >> >  rsb/configuration.rst        | 24 ++++++++++++------------
> >> >  rsb/cross-canadian-cross.rst |  2 +-
> >> >  rsb/hosts.rst                |  4 ++--
> >> >  rsb/project-sets.rst         |  4 ++--
> >> >  rsb/quick-start.rst          |  6 +++---
> >> >  rsb/third-party-packages.rst |  4 ++--
> >> >  6 files changed, 22 insertions(+), 22 deletions(-)
> >> > diff --git a/rsb/configuration.rst b/rsb/configuration.rst
> >> > index 62fc073..bf3dfaa 100644
> >> > --- a/rsb/configuration.rst
> >> > +++ b/rsb/configuration.rst
> >> > @@ -121,12 +121,12 @@ the decompression tool and all other files must
> be in the tar file format.
> >> >  The ``%source`` directive typically supports a single source file
> tar or zip
> >> >  file. The ``set`` command is used to set the URL for a specific
> source
> >> > -group. The first set command encoutner is registered and any further
> set
> >> > +group. The first set command encounter is registered and any further
> set
> >> >  commands are ignored. This allows you to define a base standard
> source location
> >> >  and override it in build and architecture specific files. You can
> also add
> >> >  extra source files to a group. This is typically done when a
> collection of
> >> >  source is broken down in a number of smaller files and you require
> the full
> >> > -package. The source's ``setup`` command must reide in the ``%prep:``
> section
> >> > +package. The source's ``setup`` command must reside in the
> ``%prep:`` section
> >> >  and it unpacks the source code ready to be built.
> >> >  If the source URL references the GitHub API server
> https://api.github.com/ a
> >> > @@ -180,7 +180,7 @@ errors that can arise.
> >> >  The protocol option lets you set a specific protocol. The ``git://``
> prefix
> >> >  used by the RSB to select a git repository can be removed using
> *none* or
> >> > -replaced with one of the standard git protcols.
> >> > +replaced with one of the standard git protocols.
> >> >  CVS
> >> > @@ -304,7 +304,7 @@ Maps are declared anywhere in the map using the
> map directive::
> >> >    1. The map is set to ``my-special-map``.
> >> > -Any macro defintions following a map declaration are placed in that
> map and the
> >> > +Any macro definitions following a map declaration are placed in that
> map and the
> >> >  default map is ``global`` when loading a file. Maps are selected in
> >> >  configuration files by using the ``%select`` directive::
> >> > @@ -315,7 +315,7 @@ if present return that value else the ``global``
> map is used. Any new macros or
> >> >  changes update only the ``global`` map. This may change in future
> releases so
> >> >  please make sure you use the ``override`` attribute.
> >> > -The macro files specificed on the command line are looked for in the
> >> > +The macro files specified on the command line are looked for in the
> >> >  ``_configdir`` paths. See <<X1,``_configdir``>> variable for
> details. Included
> >> >  files need to add the ``%{_configdir}`` macro to the start of the
> file.
> >> > @@ -494,7 +494,7 @@ To create a private configuration change to a
> suitable directory::
> >> >  and create a ``config`` directory. Here you can add a new
> configuration or
> >> >  build set file. The section 'Adding New Configurations' details how
> to add a
> >> > -new confguration.
> >> > +new configuration.
> >> >  New Configurations
> >> > @@ -597,8 +597,8 @@ source packages based on the outer configuration
> options::
> >> >  The remainder of the script is broken in to the various phases of a
> build. They
> >> >  are:
> >> > -. Preperation
> >> > -. Bulding
> >> > +. Preparation
> >> > +. Building
> >> >  . Installing, and
> >> >  . Cleaning
> >> > @@ -748,11 +748,11 @@ To build this you can use something similar to::
> >> >  The build is for a FreeBSD host and the prefix is for user installed
> >> >  packages. In this example I cannot let the source builder perform
> the install
> >> > -because I never run the RSB with root priviledges so a build set or
> bset tar
> >> > -file is created. This can then be installed using root privildges.
> >> > +because I never run the RSB with root privileges so a build set or
> bset tar
> >> > +file is created. This can then be installed using root privileges.
> >> >  The command also supplies the ``--trace`` option. The output in the
> log file
> >> > -will contian all the macros.
> >> > +will contain all the macros.
> >> >  Debugging
> >> > @@ -1320,7 +1320,7 @@ Do not include a path with the file name. Only
> the basename is required. Files
> >> >  can be searched for from a number of places and having a path
> conponent would
> >> >  create confusion. This does mean files with hashes must be unique.
> >> > -Downloading of repositories such as git and cvs cannot be
> checksumed. It is
> >> > +Downloading of repositories such as git and cvs cannot be
> checksummed. It is
> >> >  assumed those protocols and tools manage the state of the files.
> >> >  %echo
> >> > diff --git a/rsb/cross-canadian-cross.rst
> b/rsb/cross-canadian-cross.rst
> >> > index d4fce9e..039c7a7 100644
> >> > --- a/rsb/cross-canadian-cross.rst
> >> > +++ b/rsb/cross-canadian-cross.rst
> >> > @@ -36,7 +36,7 @@ To build the NTP package for RTEMS you enter the
> RSB command::
> >> >    2. The ``--host`` command is the RTEMS architecture and version.
> >> > -  3. The BSP is built and installed in the prefix. The arhcitecture
> must match
> >> > +  3. The BSP is built and installed in the prefix. The architecture
> must match
> >> >       the ``--host`` architecture.
> >> >  .. note: Installing Into Different Directories
> >> > diff --git a/rsb/hosts.rst b/rsb/hosts.rst
> >> > index a4226f3..ebcca23 100644
> >> > --- a/rsb/hosts.rst
> >> > +++ b/rsb/hosts.rst
> >> > @@ -14,7 +14,7 @@ new version of a host is known to work and it not
> listed please lets us know.
> >> >  Linux
> >> > -A number of different Linux distrubutions are known to work. The
> following have
> >> > +A number of different Linux distributions are known to work. The
> following have
> >> >  been tested and report as working.
> >> >  .. _ArchLinux:
> >> > @@ -122,7 +122,7 @@ ports::
> >> >      # portinstall --batch devel/mingw32-binutils devel/mingw32-gcc
> >> >      # portinstall --batch devel/mingw32-zlib devel/mingw32-pthreads
> >> > -The +zlip+ and +pthreads+ ports for MinGW32 are used for builiding a
> Windows
> >> > +The +zlip+ and +pthreads+ ports for MinGW32 are used for building a
> Windows
> >> >  QEMU.
> >> >  If you are on FreeBSD 10.0 and you have pkgng installed you can use
> 'pkg
> >> > diff --git a/rsb/project-sets.rst b/rsb/project-sets.rst
> >> > index 8abd080..6ca27e7 100644
> >> > --- a/rsb/project-sets.rst
> >> > +++ b/rsb/project-sets.rst
> >> > @@ -159,7 +159,7 @@ tools within that release. If the package is not
> specific to any release the
> >> >  patch can be added closer to the top under the package's name.
> Patches to fix
> >> >  specific tool related issues for a specific architecture should be
> grouped
> >> >  under the specific architecture and only applied when building that
> >> > -architecture avoiding a patch breaking an uneffected architecture.
> >> > +architecture avoiding a patch breaking an unaffected architecture.
> >> >  Patches in the RTEMS Tools repository need to be submitted to the
> upstream
> >> >  project. It should not be a clearing house for patches that will not
> be
> >> > @@ -169,7 +169,7 @@ Patches are added to a component's name and in
> the ``%prep:`` section the
> >> >  patches can be set up, meaning they are applied to source. The
> patches
> >> >  are applied in the order they are added. If there is a dependency
> make
> >> >  sure you order the patches correctly when you add them. You can add
> any
> >> > -number of patches and the RSB will handle them efficently.
> >> > +number of patches and the RSB will handle them efficiently.
> >> >  Patches can have options. These are added before the patch URL. If
> no options
> >> >  are provided the patch's setup default options are used.
> >> > diff --git a/rsb/quick-start.rst b/rsb/quick-start.rst
> >> > index f39c0a6..e39a914 100644
> >> > --- a/rsb/quick-start.rst
> >> > +++ b/rsb/quick-start.rst
> >> > @@ -429,7 +429,7 @@ A build set tar file is created by adding
> ``--bset-tar-file`` option to the
> >> >    3. Creating the build set tar file.
> >> >  You can also suppress installing the files using the ``--no-install``
> >> > -option. This is useful if your prefix is not accessiable, for
> example when
> >> > +option. This is useful if your prefix is not accessible, for example
> when
> >> >  building Canadian cross compiled tool sets::
> >> >      $ ../source-builder/sb-set-builder --log=l-sparc.txt \
> >> > @@ -462,7 +462,7 @@ building Canadian cross compiled tool sets::
> >> >  .. topic:: Items
> >> > -  1. The option to supressing installing the packages.
> >> > +  1. The option to suppressing installing the packages.
> >> >    2. Create the build set tar.
> >> > @@ -517,7 +517,7 @@ because they are implemented with the
> configuration scripts. The best way to
> >> >  find what is available is to grep the configuration files. for
> ``with`` and
> >> >  ``without``.
> >> > -Following are currentlt available:
> >> > +Following are currently available:
> >> >  ``--without-rtems``
> >> >    Do not build RTEMS when building an RTEMS build set.
> >> > diff --git a/rsb/third-party-packages.rst
> b/rsb/third-party-packages.rst
> >> > index a43abeb..1ef7c68 100644
> >> > --- a/rsb/third-party-packages.rst
> >> > +++ b/rsb/third-party-packages.rst
> >> > @@ -66,7 +66,7 @@ this may require you asking questions on the
> package's user or development
> >> >  support lists as well as RTEMS's developers list. Your porting
> effort may end
> >> >  up with a patch. RTEMS requires a patch be submitted upstream to the
> project's
> >> >  community as well as RTEMS so it can be added to the RTEMS Tools git
> >> > -repository. A patch in the RTEMS Tools git reposiitory can then be
> referenced
> >> > +repository. A patch in the RTEMS Tools git repository can then be
> referenced
> >> >  by an RSB configuration file.
> >> >  A package may create executables, for example NTP normally creates
> executables
> >> > @@ -75,7 +75,7 @@ when testing the package however they are of
> limited use by RTEMS users because
> >> >  they cannot be directly linked into a user application. Users need
> to link to
> >> >  the functions in these executables or even the executable as a
> function placed
> >> >  in libraries. If the package does not export the code in a suitable
> manner
> >> > -please contact the project's commuinity and see if you can work them
> to provide
> >> > +please contact the project's community and see if you can work them
> to provide
> >> >  a way for the code to be exported. This may be difficult because
> exporting
> >> >  internal headers and functions opens the project up to API
> compatibility issues
> >> >  they did not have before. In the simplest case attempting to get the
> code into
> >> > 2.17.1
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200331/071e653d/attachment-0001.html>
