Build Linux: FAILED devel/qemu4 on x86_64-linux-gnu (qemu-v4.1.0-x86_64-linux-gnu-1)
Anders Montonen Anders.Montonen at iki.fi
Sun May 3 08:06:14 UTC 2020
On 3 May 2020, at 8:37, Joel Sherrill <joel at rtems.org> wrote:
> This appears to fail from the m2005 release snapshot but not when building git master. This is on CentOS 7.
> Hopefully there is something useful in what was mailed out. If not, I'll dig into the saved stuff on the machine tomorrow.
<snip>
> download: https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/qemu-git-42d58e7.tar.xz <https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/qemu-git-42d58e7.tar.xz>: error: HTTP Error 404: Not Found
This looks to be the source of the failure. The file name in bare/config/devel/qemu4-git-1.cfg doesn’t match what’s on the FTP. Looking at <https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/>, the correct file name should be qemu-git-42d58e7c67.tar.xz.
Looking in the log, there were a couple of other 404s:
> download: https://ftp.rtems.org/pub/rtems/releases/4.12/4.12/sources/qemu-git-42d58e7.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.12/4.12/sources/qemu-git-42d58e7.tar.xz>: error: HTTP Error 404: Not Found
I guess this is used as a fallback location, but there is no release 4.12 directory: <https://ftp.rtems.org/pub/rtems/releases/>
> download: https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2.tar.xz <https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2.tar.xz>: error: HTTP Error 404: Not Found
> download: https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2-werror.patch <https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2-werror.patch>: error: HTTP Error 404: Not Found
bare/config/devel/qemu4.bset specifies glib-2.46.2, but the 5.0.0 snapshot contains glib-2.48.2.tar.xz. The older version and the patch are eventually found from upstream locations.
Regards,
Anders
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200503/a8b82b66/attachment.html>
