Fwd: Build Linux: FAILED devel/qemu4 on x86_64-linux-gnu (qemu-v4.1.0-x86_64-linux-gnu-1)
Joel Sherrill
joel at rtems.org
Sun May 3 05:37:16 UTC 2020
This appears to fail from the m2005 release snapshot but not when building
git master. This is on CentOS 7.
Hopefully there is something useful in what was mailed out. If not, I'll
dig into the saved stuff on the machine tomorrow.
---------- Forwarded message ---------
Date: Sat, May 2, 2020, 11:24 PM
Subject: Build Linux: FAILED devel/qemu4 on x86_64-linux-gnu
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 5.0.0-m2005-1
Host: Linux-3.10.0-1127.el7.x86_64-x86_64-with-centos-7.8.2003-Core
Linux devel.oarcorp.com 3.10.0-1127.el7.x86_64 #1 SMP Tue Mar 31
23:36:51
UTC 2020 x86_64 x86_64
Build Time: 0:04:00.153324
Build FAILED: qemu-v4.1.0-x86_64-linux-gnu-1
lang=`echo $cat | sed 's/\.gmo$//'`; \
dir=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001$destdir/$lang/LC_MESSAGES;
mkdir -p $dir; \
if test -r $cat; then \
/usr/bin/install -c -m 644 $cat $dir/glib20.mo; \
echo "installing $cat as $dir/glib20.mo"; \
else \
/usr/bin/install -c -m 644 ../../glib-2.46.2/po/$cat $dir/glib20.mo; \
echo "installing ../../glib-2.46.2/po/$cat as" \
"$dir/glib20.mo"; \
fi; \
if test -r $cat.m; then \
/usr/bin/install -c -m 644 $cat.m $dir/glib20.mo.m; \
echo "installing $cat.m as $dir/glib20.mo.m"; \
else \
if test -r ../../glib-2.46.2/po/$cat.m ; then \
/usr/bin/install -c -m 644 ../../glib-2.46.2/po/$cat.m \
$dir/glib20.mo.m; \
"$dir/glib20.mo.m"; \
else \
true; \
fi; \
fi; \
done
installing ../../glib-2.46.2/po/af.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/af/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/am.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/am/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/an.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/an/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ar.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ar/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/as.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/as/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ast.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ast/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/az.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/az/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/be.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/be/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/be at latin.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/be at latin
installing ../../glib-2.46.2/po/bg.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/bg/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/bn.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/bn/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/bn_IN.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/bn_IN/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/bs.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/bs/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ca.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ca/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ca at valencia.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ca at valencia
installing ../../glib-2.46.2/po/cs.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/cs/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/cy.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/cy/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/da.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/da/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/de.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/de/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/dz.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/dz/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/el.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/el/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/en_CA.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/en_CA/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/en_GB.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/en_GB/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/en at shaw.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/en at shaw
installing ../../glib-2.46.2/po/eo.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/eo/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/es.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/es/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/et.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/et/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/eu.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/eu/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/fa.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/fa/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/fi.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/fi/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/fr.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/fr/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ga.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ga/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/gl.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/gl/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/gu.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/gu/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/he.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/he/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/hi.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/hi/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/hr.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/hr/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/hu.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/hu/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/hy.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/hy/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/id.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/id/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/is.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/is/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/it.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/it/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ja.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ja/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ka.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ka/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/kk.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/kk/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/kn.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/kn/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ko.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ko/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ku.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ku/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/lt.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/lt/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/lv.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/lv/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/mai.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/mai/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/mg.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/mg/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/mk.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/mk/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ml.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ml/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/mn.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/mn/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/mr.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/mr/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ms.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ms/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/nb.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/nb/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/nds.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/nds/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ne.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ne/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/nl.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/nl/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/nn.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/nn/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/oc.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/oc/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/or.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/or/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/pa.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/pa/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/pl.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/pl/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ps.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ps/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/pt.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/pt/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/pt_BR.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/pt_BR/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ro.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ro/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ru.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ru/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/rw.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/rw/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/si.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/si/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/sk.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sk/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/sl.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sl/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/sq.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sq/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/sr.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sr/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/sr at latin.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sr at latin
installing ../../glib-2.46.2/po/sr at ije.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sr at ije
installing ../../glib-2.46.2/po/sv.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/sv/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ta.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ta/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/te.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/te/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/tg.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/tg/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/th.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/th/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/tl.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/tl/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/tr.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/tr/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/ug.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/ug/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/tt.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/tt/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/uk.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/uk/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/vi.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/vi/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/wa.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/wa/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/xh.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/xh/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/yi.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/yi/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/zh_CN.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/zh_CN/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/zh_HK.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/zh_HK/LC_MESSAGES/glib20.mo
installing ../../glib-2.46.2/po/zh_TW.gmo as
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale/zh_TW/LC_MESSAGES/glib20.mo
if test "glib" = "glib"; then \
mkdir -p
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/glib-2.0/gettext/po;
/usr/bin/install -c -m 644 ../../glib-2.46.2/po/Makefile.in.in \
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/glib-2.0/gettext/po/
Makefile.in.in; \
else \
fi
make[2]: Leaving directory
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/po'
Making install in docs
make[2]: Entering directory
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/docs'
Making install in reference
make[3]: Entering directory
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/docs/reference'
Making install in glib
make[4]: Entering directory
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/docs/reference/glib'
make[5]: Entering directory
make[5]: Nothing to be done for `install-exec-am'.
Nothing to install
make[5]: Leaving directory
make[4]: Leaving directory
Making install in gobject
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/docs/reference/gobject'
Nothing to install
Making install in gio
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/docs/reference/gio'
Nothing to install
make[5]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory
make[4]: Nothing to be done for `install-exec-am'.
make[4]: Nothing to be done for `install-data-am'.
Making install in tests
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/tests'
make install-recursive
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/tests/gobject'
make install-am
make[6]: Entering directory
make[6]: Nothing to be done for `install-exec-am'.
make[6]: Leaving directory
Making install in refcount
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build/tests/refcount'
make install-am
make[1]: Leaving directory
`/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/build'
+ cd
sizes: glib-2.46.2-x86_64-linux-gnu-1: 158.620MB (installed: 23.420MB)
cleaning: glib-2.46.2-x86_64-linux-gnu-1
run: /bin/sh -ex
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1/do-clean
+ export
SB_ORIG_PATH=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/joel/.local/bin:/home/joel/bin
+ SB_PREFIX=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
++ echo /home/joel/rtems-cron-5.0.0-m2005-1/tools/5
++ /bin/sed -e 's/^\///'
+ SB_PREFIX_CLEAN=home/joel/rtems-cron-5.0.0-m2005-1/tools/5
SB_SOURCE_DIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/sources
SB_BUILD_DIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1
+ SB_HOST_CPPFLAGS=
+ SB_HOST_CFLAGS='-O2 -g -pipe '
+ SB_HOST_CXXFLAGS='-O2 -g -pipe '
+ SB_HOST_LDFLAGS='
-L/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/lib'
+ SB_HOST_LIBS=
+ SB_BUILD_CFLAGS='-O2 -g -pipe
-I/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/include'
+ SB_BUILD_CXXFLAGS='-O2 -g -pipe
+ SB_BUILD_LDFLAGS='
+ SB_BUILD_LBS=
+ SB_CFLAGS='-O2 -g -pipe
+ SB_CXXFLAGS='-O2 -g -pipe
+ SB_ARCH=x86_64
+ SB_OS=linux
+ export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
+ export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
SB_HOST_LIBS
+ export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
+ export SB_CFLAGS SB_CXXFLAGS
+ SB_DOC_DIR=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/doc
+ export SB_DOC_DIR
+ SB_PACKAGE_NAME=glib-2.46.2-x86_64-linux-gnu-1
+ SB_PACKAGE_BUILDNAME=glib-2.46.2-x86_64-linux-gnu-1
+ SB_PACKAGE_VERSION=2.46.2
+ SB_PACKAGE_RELEASE=1
+ export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
+ export SB_PREFIX
SB_BUILD_ROOT=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001
SB_BUILD_ROOT_BINDIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
+ export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
SB_BUILD_CXC_DIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/glib-2.46.2-x86_64-linux-gnu-1-cxc
SB_BUILD_CXC_ROOT=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001-cxc
SB_BUILD_CXC_ROOT_BINDIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001-cxc/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
+ export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
SB_TMPROOT=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4
SB_TMPPREFIX=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
SB_TMPBINDIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
+ export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
SB_TMPCXCROOT=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4
SB_TMPCXCPREFIX=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
SB_TMPCXCBINDIR=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
+ export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
SB_EXTRAPATH=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/source-builder
+ export CFLAGS_FOR_TARGET
+ export CXXFLAGS_FOR_TARGET
+ test -n
PATH=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/joel/.local/bin:/home/joel/bin
+ test -n
PATH=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/joel/.local/bin:/home/joel/bin
+ test -n
PATH=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/source-builder:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/joel/.local/bin:/home/joel/bin
PATH=/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-staging/bin:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/source-builder:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/joel/.local/bin:/home/joel/bin
+ export PATH
+ LANG=C
+ export LANG
+ unset DISPLAY
+ umask 022
+ cd
+ echo '=> glib-2.46.2-x86_64-linux-gnu-1: CLEAN'
+ echo '==> %clean:'
==> %clean:
copy:
reporting: devel/glib-2.46.2-1.cfg -> glib-2.46.2-x86_64-linux-gnu-1.txt
loading: glib-2.0
get: requires ()
get: requires.private ()
checking: glib-2.0 >= 0
check: glib-2.0 not found
making dir:
/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/glib-2.46.2-x86_64-linux-gnu-1-1001/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/rtems/rsb
loading: glib-2.0
get: requires ()
reporting: devel/glib-2.46.2-1.cfg -> glib-2.46.2-x86_64-linux-gnu-1.xml
loading: glib-2.0
get: requires ()
making dir:
loading: glib-2.0
get: requires ()
config: devel/qemu4-git-1.cfg
loading: vdeplug
get: requires ()
checking: vdeplug >= 0
check: vdeplug not found
package: qemu-v4.1.0-x86_64-linux-gnu-1
script: 1: #!/bin/sh
script: 2: # ___build_pre as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/joel/rtems-cron-5.0.0-m2005-1/tools/5"
script: 7: SB_PREFIX_CLEAN=$(echo
"/home/joel/rtems-cron-5.0.0-m2005-1/tools/5" | /bin/sed -e 's/^\///')
script: 8:
SB_SOURCE_DIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/sources"
script: 9:
SB_BUILD_DIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/qemu-v4.1.0-x86_64-linux-gnu-1"
script: 10: # host == build, use build; host != build, host uses host and
build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: # Optionally do not add includes to c/cxx flags as newer
configure's complain
script: 13: SB_HOST_CFLAGS="-O2 -g -pipe "
script: 14: SB_HOST_CXXFLAGS="-O2 -g -pipe "
script: 15: SB_HOST_LDFLAGS="
-L/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/${SB_PREFIX_CLEAN}/lib"
script: 16: SB_HOST_LIBS=""
script: 17: SB_BUILD_CFLAGS="-O2 -g -pipe
-I/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/${SB_PREFIX_CLEAN}/include"
script: 18: SB_BUILD_CXXFLAGS="-O2 -g -pipe
script: 19: SB_BUILD_LDFLAGS="
script: 20: SB_BUILD_LBS=""
script: 21: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 22: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 23: SB_ARCH="x86_64"
script: 24: SB_OS="linux"
script: 25: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 26: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS
SB_HOST_LDFLAGS SB_HOST_LIBS
script: 27: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
SB_BUILD_LIBS
script: 28: export SB_CFLAGS SB_CXXFLAGS
script: 29: # Documentation
script: 30:
SB_DOC_DIR="/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/doc"
script: 31: export SB_DOC_DIR
script: 32: # Packages
script: 33: SB_PACKAGE_NAME="qemu-v4.1.0-x86_64-linux-gnu-1"
script: 34: SB_PACKAGE_BUILDNAME="qemu-v4.1.0-x86_64-linux-gnu-1"
script: 35: SB_PACKAGE_VERSION="v4.1.0"
script: 36: SB_PACKAGE_RELEASE="1"
script: 37: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 38: # Build directories
script: 39: export SB_PREFIX
script: 40:
script: 41:
SB_BUILD_ROOT="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/qemu-v4.1.0-x86_64-linux-gnu-1-1001"
script: 42:
SB_BUILD_ROOT_BINDIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/qemu-v4.1.0-x86_64-linux-gnu-1-1001/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 44:
SB_BUILD_CXC_DIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/qemu-v4.1.0-x86_64-linux-gnu-1-cxc"
script: 45:
SB_BUILD_CXC_ROOT="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/qemu-v4.1.0-x86_64-linux-gnu-1-1001-cxc"
script: 46:
SB_BUILD_CXC_ROOT_BINDIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/qemu-v4.1.0-x86_64-linux-gnu-1-1001-cxc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR
script: 48:
SB_TMPROOT="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4"
script: 49:
SB_TMPPREFIX="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/${SB_PREFIX_CLEAN}"
script: 50:
SB_TMPBINDIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 52:
SB_TMPCXCROOT="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001/devel/qemu4"
script: 53:
SB_TMPCXCPREFIX="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/${SB_PREFIX_CLEAN}"
script: 54:
SB_TMPCXCBINDIR="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-cxc/devel/qemu4/${SB_PREFIX_CLEAN}/bin"
script: 55: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 56: # Extra path support
script: 57:
SB_EXTRAPATH="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/source-builder"
script: 58: # The compiler flags
script: 59:
script: 60:
script: 61: export CFLAGS_FOR_TARGET
script: 62: export CXXFLAGS_FOR_TARGET
script: 63: # Set up the path. Put the CXC path first.
script: 64: if test -n "${SB_TMPBINDIR}" ; then
script: 65: PATH="${SB_TMPBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 68: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 69: fi
script: 70: if test -n "${SB_EXTRAPATH}" ; then
script: 71: PATH="${SB_EXTRAPATH}:$PATH"
script: 72: fi
script: 73:
PATH="/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/bare/build/tmp/sb-1001-staging/bin:$PATH"
script: 74:
script: 75: export PATH
script: 76: # Default environment set up.
script: 77: LANG=C
script: 78: export LANG
script: 79: unset DISPLAY || :
script: 80: umask 022
script: 81: cd
script: 82: echo "=> qemu-v4.1.0-x86_64-linux-gnu-1: BUILD"
script: 83: echo "==> %prep:"
script: 84: build_top=$(pwd)
script: 85: source_dir_qemu="qemu-v4.1.0"
source setup: qemu-v4.1.0-x86_64-linux-gnu-1: source qemu -q -n qemu-v4.1.0
making dir:
download: (full)
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/qemu-git-42d58e7.tar.xz
-> sources/qemu-git-42d58e7.tar.xz
download:
download: no ssl context
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/qemu-git-42d58e7.tar.xz:
error: HTTP Error 404: Not Found
download: (full)
https://ftp.rtems.org/pub/rtems/releases/4.12/4.12/sources/qemu-git-42d58e7.tar.xz
download:
download:
https://ftp.rtems.org/pub/rtems/releases/4.12/4.12/sources/qemu-git-42d58e7.tar.xz:
error: downloading
all paths have failed, giving up
See error report: rsb-report-qemu-v4.1.0-x86_64-linux-gnu-1.txt
Output
Build Set: devel/qemu4
config: devel/libiconv-1.14-1.cfg
config: devel/gettext-0.18.3.1-1.cfg
package: gettext-0.18.3.1-x86_64-linux-gnu-1
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/gettext-0.18.3.1.tar.gz
-> sources/gettext-0.18.3.1.tar.gz
building: gettext-0.18.3.1-x86_64-linux-gnu-1
sizes: gettext-0.18.3.1-x86_64-linux-gnu-1: 158.588MB (installed: 20.210MB)
cleaning: gettext-0.18.3.1-x86_64-linux-gnu-1
reporting: devel/gettext-0.18.3.1-1.cfg ->
gettext-0.18.3.1-x86_64-linux-gnu-1.txt
gettext-0.18.3.1-x86_64-linux-gnu-1.xml
config: devel/libffi-3.0.13-1.cfg
package: libffi-3.0.13-x86_64-linux-gnu-1
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/libffi-3.0.13.tar.gz
-> sources/libffi-3.0.13.tar.gz
Creating source directory: patches
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/libffi-pkg-conf...<see
log> -> patches/libffi-pkg-config-lib64-fix.diff
building: libffi-3.0.13-x86_64-linux-gnu-1
sizes: libffi-3.0.13-x86_64-linux-gnu-1: 5.720MB (installed: 449.565KB)
cleaning: libffi-3.0.13-x86_64-linux-gnu-1
reporting: devel/libffi-3.0.13-1.cfg -> libffi-3.0.13-x86_64-linux-gnu-1.txt
reporting: devel/libffi-3.0.13-1.cfg -> libffi-3.0.13-x86_64-linux-gnu-1.xml
config: devel/pixman-0.32.4-1.cfg
package: pixman-0.32.4-x86_64-linux-gnu-1
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/pixman-0.32.4.tar.gz
-> sources/pixman-0.32.4.tar.gz
building: pixman-0.32.4-x86_64-linux-gnu-1
sizes: pixman-0.32.4-x86_64-linux-gnu-1: 66.774MB (installed: 15.799MB)
cleaning: pixman-0.32.4-x86_64-linux-gnu-1
reporting: devel/pixman-0.32.4-1.cfg -> pixman-0.32.4-x86_64-linux-gnu-1.txt
reporting: devel/pixman-0.32.4-1.cfg -> pixman-0.32.4-x86_64-linux-gnu-1.xml
config: devel/glib-2.46.2-1.cfg
package: glib-2.46.2-x86_64-linux-gnu-1
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2.tar.xz
-> sources/glib-2.46.2.tar.xz
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2.tar.xz:
download:
http://ftp.gnome.org/pub/gnome/sources/glib/2.46/glib-2.46.2.tar.xz ->
redirect:
http://gensho.ftp.acc.umu.se/pub/gnome/sources/glib/2.46/glib-2.46.2.tar.xz
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2-werror.patch
-> patches/glib-2.46.2-werror.patch
download:
https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-1/sources/glib-2.46.2-werror.patch:
download: https://gaisler.se/qemu/glib-2.46.2-werror.patch ->
building: glib-2.46.2-x86_64-linux-gnu-1
download:
download:
download:
download:
error: downloading
Build FAILED
error: downloading
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Sat May 2 23:21:27 2020
Report: devel/gettext-0.18.3.1-1.cfg
RTEMS Source Builder Release
Version: 5.0.0-m2005-1
Build Set: (1) devel/gettext-0.18.3.1-1.cfg
Build Set: (2) devel/gettext-0.18.3.1-1.cfg
Package: gettext-0.18.3.1-x86_64-linux-gnu-1
Config: devel/gettext-0.18.3.1-1.cfg
Summary:
GetText offers to programmers, translators, and even users, a well
integrated set of tools and documentation.
URL:
http://www.gnu.org/software/gettext/
Version:
0.18.3.1
Release:
1
Sources: 1
1: http://ftp.gnu.org/pub/gnu/gettext/gettext-0.18.3.1.tar.gz
sha256:
0d8f9a33531b77776b3dc473e7940019ca19bfca5b4c06db6e96065eeb07245d
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_gettext="gettext-0.18.3.1"
%setup source gettext -q -n gettext-0.18.3.1
%setup patch gettext -p1
cd ${build_top}
Build:
build_top=$(pwd)
if test "x86_64-linux-gnu" != "x86_64-linux-gnu" ; then
# Cross-build (Xc) if no target or the host and target match.
# Canadian-cross (Cxc) if build, host and target are all different.
if test -z "" -o "x86_64-linux-gnu" == "" ; then
build_dir="build-xc"
else
build_dir="build-cxc"
fi
else
build_dir="build"
fi
mkdir -p ${build_dir}
cd ${build_dir}
# Host and build flags, Cross build if host and build are different and
# Cxc build if target is deifned and also different.
# Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
# Cross build
CC=$(echo "x86_64-linux-gnu-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "x86_64-linux-gnu-g++" | sed -e 's,-std=gnu99 ,,')
CPPFLAGS="${SB_HOST_CPPFLAGS}"
CFLAGS="${SB_HOST_CFLAGS}"
CXXFLAGS="${SB_HOST_CXXFLAGS}"
LDFLAGS="${SB_HOST_LDFLAGS}"
LDLIBS="${SB_HOST_LIBS}"
# Host
CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
# Build
CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CC_FOR_BUILD=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_BUILD=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
else
LDFLAGS="${SB_BUILD_LDFLAGS}"
LDLIBS="${SB_BUILD_LIBS}"
CC=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
CC_FOR_BUILD=${CC}
CXX_FOR_BUILD=${CXX}
fi
export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
../${source_dir_gettext}/configure
--prefix=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
--bindir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
--exec_prefix=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
--includedir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/include
--libdir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/lib
--libexecdir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/libexec
--mandir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man
--infodir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/info
--datadir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share
--build=x86_64-linux-gnu --host=x86_64-linux-gnu
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
/bin/rm -rf $SB_BUILD_ROOT
cd ${build_dir}
make DESTDIR=$SB_BUILD_ROOT install
cd ${build_top}
Summary:
URL:
Version:
0.18.3.1
Release:
1
Sources: 1
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 2 23:21:43 2020
Report: devel/libffi-3.0.13-1.cfg
Build Set: (1) devel/libffi-3.0.13-1.cfg
Build Set: (2) devel/libffi-3.0.13-1.cfg
Package: libffi-3.0.13-x86_64-linux-gnu-1
Config: devel/libffi-3.0.13-1.cfg
Summary:
LibFFI provides a portable, high level programming interface to
various calling conventions.
URL:
https://sourceware.org/libffi/
Version:
3.0.13
Release:
1
Sources: 1
1: https://sourceware.org/pub/libffi/libffi-3.0.13.tar.gz
sha256:
1dddde1400c3bcb7749d398071af88c3e4754058d2d4c0b3696c2f82dc5cf11c
Patches: 1
1:
http://git.rtems.org/rtems-tools/plain/tools//libffi/libffi-pkg-config-lib64-fix.diff
sha256:
f858658b7b57db13002987b7d6bb0293f181519032bf4dd36969ccb79d6b16a3
Preparation:
build_top=$(pwd)
source_dir_libffi="libffi-3.0.13"
%setup source libffi -q -n libffi-3.0.13
%setup patch libffi -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_libffi}/configure
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
Summary:
URL:
Version:
3.0.13
Release:
1
Sources: 1
sha256:
Patches: 1
1:
sha256:
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 2 23:22:06 2020
Report: devel/pixman-0.32.4-1.cfg
Build Set: (1) devel/pixman-0.32.4-1.cfg
Build Set: (2) devel/pixman-0.32.4-1.cfg
Package: pixman-0.32.4-x86_64-linux-gnu-1
Config: devel/pixman-0.32.4-1.cfg
Summary:
Pixman is a low-level software library for pixel manipulation,
providing features such as image compositing and trapezoid
rasterization.
URL:
http://www.pixman.org/
Version:
0.32.4
Release:
1
Sources: 1
1: http://cairographics.org/releases/pixman-0.32.4.tar.gz
sha256:
80c7ed420e8a3ae749800241e6347c3d55681296cab71384be7969cd9e657e84
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_pixman="pixman-0.32.4"
%setup source pixman -q -n pixman-0.32.4
%setup patch pixman -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200503/396525d9/attachment-0001.html>
