RSB fails to build qemu.bset
Cláudio Maia clrrm at isep.ipp.pt
Mon May 4 09:20:54 UTC 2020
On 04/05/20 00:29, Chris Johns wrote:
> On 3/5/20 4:33 am, Joel Sherrill wrote:
>> On Sat, May 2, 2020, 12:42 PM Cláudio Maia <clrrm at isep.ipp.pt
>> <mailto:clrrm at isep.ipp.pt>> wrote:
>>     Hello everyone,
>>     I'm trying to build the toolchain for the build set devel/qemu.bset
>>     with the goal of executing RTEMS applications on top of LEON3 bsp on
>>     QEMU.
>>     Unfortunately, when I build the toolchain using:
<snip>
>> If this is a recent Linux distribution, try the qemu4 bset.
>> The qemu.bset is for an older version of qemu which seems to have build
>> issues on newer hosts.
> I do not recall why we have both? Is there a need?
>> Qemu5 was also recently released.
>> I suspect we need to renamed this to have a major number on the end.
>> That might encourage picking a newer release.
> Do we need the major version number on the end? Why do we have it there?
>> FWIW qemu4 builds on Centos 7 which means newer qemu on older Linux
>> works where older qemu on newer Linux doesn't.
> What hosts build qemu4?
I'm using Ubuntu 18.04.4 LTS with kernel version 4.15.0-99-generic 64-bit version.
> chris
