clang sparc: generated .o file incompatible with elf64-x86-64
    Joel Sherrill
    joel at rtems.org
    Mon May  4 12:19:30 UTC 2020
On Mon, May 4, 2020, 7:16 AM suyash singh <suyashsingh234 at gmail.com> wrote:
> I am trying to cross compile with clang and run Undefined Behavior
> Sanitizer for .c file
> *Command I am running*
> clang -target sparc -integrated-as -fuse-ld=lld -fsanitize=undefined test1.c
> clang is the cross compiler
> sparc is the target architecture.
> -integrated-as to use the llvm assembler
> -fuse-ld=lld to use lld linker
> -fsanitize=undefined to run UBSan
> *Error*
> ld.lld: error: /tmp/test1-43c7c0.o is incompatible with elf64-x86-64
> collect2: error: ld returned 1 exit status
> clang-11: error: linker (via gcc) command failed with exit code 1 (use -v
> to see invocation)
> *My system*
> Ubuntu 18.04
> x86_64
> command executed on ubuntu terminal
> without -target sparc on a file.c which does not contain sparc assembly
> the clang works fine
This is the same problem you had with as. You need to properly specify the
target and have the target as and ld in your PATH.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200504/eb1d72fc/attachment-0001.html>
