clang sparc: generated .o file incompatible with elf64-x86-64
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Mon May 4 12:34:36 UTC 2020
On Mon, 4 May 2020 at 13:19, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, May 4, 2020, 7:16 AM suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> I am trying to cross compile with clang and run Undefined Behavior
>> Sanitizer for .c file
>> *Command I am running*
>> clang -target sparc -integrated-as -fuse-ld=lld -fsanitize=undefined test1.c
>> clang is the cross compiler
>> sparc is the target architecture.
>> -integrated-as to use the llvm assembler
>> -fuse-ld=lld to use lld linker
>> -fsanitize=undefined to run UBSan
>> *Error*
>> ld.lld: error: /tmp/test1-43c7c0.o is incompatible with elf64-x86-64
>> collect2: error: ld returned 1 exit status
>> clang-11: error: linker (via gcc) command failed with exit code 1 (use -v
>> to see invocation)
>> *My system*
>> Ubuntu 18.04
>> x86_64
>> command executed on ubuntu terminal
>> without -target sparc on a file.c which does not contain sparc assembly
>> the clang works fine
> This is the same problem you had with as. You need to properly specify the
> target and have the target as and ld in your PATH.
Also can you add -v and send the output?
> --joel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200504/b3a95723/attachment.html>
