m2005 untar error on msys2 (tar01 directory)
Sebastian Huber
Tue May 5 07:01:23 UTC 2020
On 05/05/2020 08:57, Chris Johns wrote:
> On 5/5/20 4:05 pm, Sebastian Huber wrote:
>> On 05/05/2020 08:01, Chris Johns wrote:
>>>>> What does `os.uname()` return?
>>>> In the msys shell:
>>>> $ python
>>>> Python 3.7.4 (default, Jul 11 2019, 09:35:14)
>>> That is what I have installed.
>>>> [GCC 9.1.0] on msys
>>>> Type "help", "copyright", "credits" or "license" for more information.
>>>> >>> import os
>>>> >>> os.uname()
>>>> posix.uname_result(sysname='MSYS_NT-6.1-7601', nodename='Blub',
>>>> release='3.0.7-338.x86_64', version='2019-07-11 10:58 UTC',
>>>> machine='x86_64')
>>> I have ...
>>> >>> os.uname()
>>> posix.uname_result(sysname='MINGW64_NT-10.0-18362', nodename='weng',
>>> machine='x86_64')
>>> I have never seen `MSYS_NT` before.
>>> I am running Window-10 on real hardware running Version 1903, OS
>>> build 18362.778. I have not picked up the feature update yet. I am
>>> remote to the machine and do not want to try.
>> I did the testing on a more or less retired Windows 7 VM. I will
>> setup a Windows 10 VM.
> Oh OK, maybe keep it? Could you patch the RSB and see if it works?
I removed the GDB from the build set. It is currently busy building the
5/rtems-sparc build set (without GDB) in a mingw64 shell. Is a build in
the msys shell something useful/supported? I normally build the mingw64
tools on Linux.
